Ga door naar hoofdinhoud
Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement
Wat je nodig hebt
  1. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement, LED/Speaker Board and Microphone: stap 1, afbeelding 1 van 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement, LED/Speaker Board and Microphone: stap 1, afbeelding 2 van 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement, LED/Speaker Board and Microphone: stap 1, afbeelding 3 van 3
    • Power off and unplug the echo
    • Using the plastic opening tool, peel off the rubber layer on the bottom of the echo.
  2. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: stap 2, afbeelding 1 van 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: stap 2, afbeelding 2 van 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: stap 2, afbeelding 3 van 3
    • Use the T8 screwdriver bit to unscrew the four 1.6mm torx screws
    • Remove the black cylindrical base
  3. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: stap 3, afbeelding 1 van 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: stap 3, afbeelding 2 van 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: stap 3, afbeelding 3 van 3
    • Use the metal spudger to lift the ZIF connector
    • Remove the ribbon cable from the slot
  4. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: stap 4, afbeelding 1 van 1
    • Remove the motherboard
  5. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: stap 5, afbeelding 1 van 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: stap 5, afbeelding 2 van 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: stap 5, afbeelding 3 van 3
    • Remove the silver divider
    • Remove black rubber divider
    • Remove the plastic white frame
  6. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: stap 6, afbeelding 1 van 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: stap 6, afbeelding 2 van 3 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: stap 6, afbeelding 3 van 3
    • Remove the ribbon cable from the slot on the LED/speaker board
  7. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: stap 7, afbeelding 1 van 1
    • Remove the LED/speaker board
Conclusie
4 andere personen hebben deze handleiding voltooid.
Cassidy O'Connor
450 Reputatie
2 handleidingen geschreven
USF Tampa, Team S1-G3, Leahy Fall 2017 Lid van USF Tampa, Team S1-G3, Leahy Fall 2017
USFT-LEAHY-F17S1G3
3 Leden
12 handleidingen geschreven
Één opmerking
I can’t seem to find the board anywhere. Where would you buy one?
George hanes - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 37
Altijd: 4,841
