Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
Use this guide to replace the 4-in-1 WiFi/Bluetooth/FM/GPS board on the Amazon Echo Dot 2nd generation. The 4-in-1 is located on the motherboard, so the whole board must be replaced, rather than replacing each individual component.
  1. Power off and unplug the echo Using the plastic opening tool, peel off the rubber layer on the bottom of the echo Using the plastic opening tool, peel off the rubber layer on the bottom of the echo
    • Power off and unplug the echo
    • Using the plastic opening tool, peel off the rubber layer on the bottom of the echo
  2. Use a T8 screwdriver bit to unscrew the four 1.6mm torx screws Remove the black cylindrical base Remove the black cylindrical base
    • Use a T8 screwdriver bit to unscrew the four 1.6mm torx screws
    • Remove the black cylindrical base
  3. Use the metal spudger to lift the ZIF connector Remove the ribbon cable from the slot Remove the ribbon cable from the slot
    • Use the metal spudger to lift the ZIF connector
    • Remove the ribbon cable from the slot
  4. Remove the motherboard
    • Remove the motherboard
Conclusie
5 andere personen hebben deze handleiding voltooid.
Alexis White
381 Reputatie
2 handleidingen geschreven
USF Tampa, Team S1-G3, Leahy Fall 2017 Lid van USF Tampa, Team S1-G3, Leahy Fall 2017
USFT-LEAHY-F17S1G3
3 Leden
10 handleidingen geschreven
Where can I find the part my dot won’t connect and I have been going crazy trying to find the motherboard
IT's Tech - Antwoord
I wish to recommend not removing the adhesive layer if you plan to reassemble this Echo Dot. I would suggest poking holes to reach the four screws instead. Then reassembly can reuse the same adhesive layer.
rayramirez - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 74
Altijd: 4,447
