Inleiding
Use this guide to replace the 4-in-1 WiFi/Bluetooth/FM/GPS board on the Amazon Echo Dot 2nd generation. The 4-in-1 is located on the motherboard, so the whole board must be replaced, rather than replacing each individual component.
Wat je nodig hebt
Power off and unplug the echo
Using the plastic opening tool, peel off the rubber layer on the bottom of the echo
8 andere personen hebben deze handleiding voltooid.
2Gids Commentaar
Where can I find the part my dot won’t connect and I have been going crazy trying to find the motherboard
I wish to recommend not removing the adhesive layer if you plan to reassemble this Echo Dot. I would suggest poking holes to reach the four screws instead. Then reassembly can reuse the same adhesive layer.
