Inleiding
Follow this guide to replace the subwoofer in your device if you are experiencing any sort of audio issues.
Wat je nodig hebt
Remove the rubber layer beneath the device.
Look for the crater beneath the rubber layer and place your thumb on it. Hold down and lift off the cover with your other hand.
Remove the four 8.0 mm T8 Torx screws on the lid.
Remove the lid from the device.
Remove the four 30.0 mm T8 Torx screws in the corners.
Remove the large plastic piece on top of the subwoofer while threading the ribbon cable and male connector through the hole.
Één andere persoon heeft deze handleiding voltooid.
