Ga door naar hoofdinhoud
Amazon Echo 2nd Generation MLB Board Replacement
Wat je nodig hebt
  1. Amazon Echo 2nd Generation MLB Board Replacement, AMP Board: stap 1, afbeelding 1 van 3 Amazon Echo 2nd Generation MLB Board Replacement, AMP Board: stap 1, afbeelding 2 van 3 Amazon Echo 2nd Generation MLB Board Replacement, AMP Board: stap 1, afbeelding 3 van 3
    • Remove the rubber layer beneath the device.
    • Look for the crater beneath the rubber layer and place your thumb on it. Hold down and lift off the cover with your other hand.
    • Remove the four 8.0 mm T8 Torx screws on the lid.
    • Remove the lid from the device.
  2. Amazon Echo 2nd Generation MLB Board Replacement: stap 2, afbeelding 1 van 3 Amazon Echo 2nd Generation MLB Board Replacement: stap 2, afbeelding 2 van 3 Amazon Echo 2nd Generation MLB Board Replacement: stap 2, afbeelding 3 van 3
    • Use a spudger to flip up the small flap on the ZIF connector.
    • Gently pull the ribbon cable out of the ZIF connector.
    • Lift the AMP Board gently while sliding the ribbon cable out through the center hole to reveal another set of wires underneath the board.
  3. Amazon Echo 2nd Generation MLB Board Replacement: stap 3, afbeelding 1 van 2 Amazon Echo 2nd Generation MLB Board Replacement: stap 3, afbeelding 2 van 2
    • Use a spudger to lift up one of the small flaps on only one side of the female connector.
    • Pull on the wire toward the lifted side until the male connector is disconnected.
    • Remove the AMP Board.
  4. Amazon Echo 2nd Generation MLB Board Replacement, Subwoofer (speaker): stap 4, afbeelding 1 van 2 Amazon Echo 2nd Generation MLB Board Replacement, Subwoofer (speaker): stap 4, afbeelding 2 van 2
    • Remove the four 30.0 mm T8 Torx screws in the corners.
    • Remove the large plastic piece on top of the subwoofer while threading the ribbon cable and male connector through the hole.
  5. Amazon Echo 2nd Generation MLB Board Replacement: stap 5, afbeelding 1 van 2 Amazon Echo 2nd Generation MLB Board Replacement: stap 5, afbeelding 2 van 2
    • Remove the lid on top of the subwoofer.
    • Flip the device over and let the subwoofer fall into your hand.
    • The subwoofer is a strong magnet. Keep it away from any other electronics and unshielded wires.
  6. Amazon Echo 2nd Generation MLB Board Replacement, MIC Board: stap 6, afbeelding 1 van 3 Amazon Echo 2nd Generation MLB Board Replacement, MIC Board: stap 6, afbeelding 2 van 3 Amazon Echo 2nd Generation MLB Board Replacement, MIC Board: stap 6, afbeelding 3 van 3
    • Lift the MIC board over and lay it down against a surface.
    • Disconnect the ribbon cable from the MIC board and pull the board away.
  7. Amazon Echo 2nd Generation MLB Board Replacement, Front Cover Panel: stap 7, afbeelding 1 van 2 Amazon Echo 2nd Generation MLB Board Replacement, Front Cover Panel: stap 7, afbeelding 2 van 2
    • Remove the four 16.0 mm T8 Torx screws underneath the speaker.
    • Once you unscrew the four 16.0 mm T8 Torx screws, the remaining components of the device have no support. Take caution when flipping the device over to avoid damage to the remaining components.
    • Flip the device over while supporting the front panel side.
    • Remove the front panel cover by lifting it.
  8. Amazon Echo 2nd Generation MLB Board Replacement, MLB Board: stap 8, afbeelding 1 van 2 Amazon Echo 2nd Generation MLB Board Replacement, MLB Board: stap 8, afbeelding 2 van 2
    • Remove the white plastic shielding and the black silicon cover.
    • Remove the metal cover beneath the black silicon cover.
  9. Amazon Echo 2nd Generation MLB Board Replacement: stap 9, afbeelding 1 van 1
    • Carefully lift up the MLB board. Underneath it is another ZIF connector. Use a spudger to flip the small flap on the ZIF connector.
    • This will take a few tries to get it done correctly. Remember to not use too much force as you do not want to damage the ZIF connector.
    • Remove the MLB Board by flipping the device over and letting it fall into your hands.
    • Completely remove the ribbon cable from the case, reattach it to the MLB board, then place the board and ribbon cable back into its original position.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Billy Pho
437 Reputatie
2 handleidingen geschreven
Cal Poly, Team S4-G4, White Fall 2018 Lid van Cal Poly, Team S4-G4, White Fall 2018
CPSU-WHITE-F18S4G4
3 Leden
5 handleidingen geschreven
3 opmerkingen
Hi,
where can i can the MLB board?
Pierre Troussard - Antwoord
Have you managed to source one yet?
Neil -
Yes, where does on get the MLB board?
Neil - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 48
Altijd: 3,355
