Inleiding
If you are having issues controlling the volume on your device, this guide will show you how to remove and replace the daughterboard that connects to the volume and microphone buttons.
Wat je nodig hebt
Use blue plastic opening tool to remove the external speaker face by placing it in the slight opening at the bottom.
Use a lever motion, push the tool down, lifting the speaker face.
Use fingers to grip and remove speaker face.
Repeat on reverse side to remove the second speaker face.
Orient speaker so volume buttons are facing up.
Remove rubber button piece using the blue plastic opening tool.
