Ga door naar hoofdinhoud
Altec Lansing VersA Smart Bluebooth Board Replacement
Wat je nodig hebt
  1. Altec Lansing VersA Smart Bluebooth Board Replacement, External Panels: stap 1, afbeelding 1 van 1
    • Remove external rubber cover.
  2. Altec Lansing VersA Smart Bluebooth Board Replacement: stap 2, afbeelding 1 van 2 Altec Lansing VersA Smart Bluebooth Board Replacement: stap 2, afbeelding 2 van 2
    • Use blue plastic opening tool to remove the external speaker face by placing it in the slight opening at the bottom.
    • Use a lever motion, push the tool down, lifting the speaker face.
    • Use fingers to grip and remove speaker face.
    • Repeat on reverse side to remove the second speaker face.
  3. Altec Lansing VersA Smart Bluebooth Board Replacement: stap 3, afbeelding 1 van 2 Altec Lansing VersA Smart Bluebooth Board Replacement: stap 3, afbeelding 2 van 2
    • Orient speaker so volume buttons are facing away from you, and Bluetooth and power buttons are on the left-hand side.
    • Remove the seven 14mm screws using the Phillips #1 screwdriver.
  4. Altec Lansing VersA Smart Bluebooth Board Replacement: stap 4, afbeelding 1 van 1
    • Reorient speaker so Bluetooth and power buttons are now on the right-hand side.
    • Separate the two panels along the crease.
    • Blue plastic opening tool may be needed to separate panels.
    • Remove the panel with no buttons to expose internal area of the device.
    • Motherboard and all internal components are under this panel.
  5. Altec Lansing VersA Smart Bluebooth Board Replacement, Bluebooth Board: stap 5, afbeelding 1 van 1
    • Detach the wiring piece, located in the upper right corner of the motherboard.
  6. Altec Lansing VersA Smart Bluebooth Board Replacement: stap 6, afbeelding 1 van 2 Altec Lansing VersA Smart Bluebooth Board Replacement: stap 6, afbeelding 2 van 2
    • Remove the daughterboard piece from its designated slot, located to the right of the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Rachael Hopp
550 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 700
