Ga door naar hoofdinhoud
AlphaSmart Pro Lithium Coin Battery Replacement
Wat je nodig hebt
  1. AlphaSmart Pro Lithium Coin Battery Replacement, Separating Panels: stap 1, afbeelding 1 van 3 AlphaSmart Pro Lithium Coin Battery Replacement, Separating Panels: stap 1, afbeelding 2 van 3 AlphaSmart Pro Lithium Coin Battery Replacement, Separating Panels: stap 1, afbeelding 3 van 3
    • Removing the lithium coin battery will erase existing files. Make sure all important files have been safely transferred to another device before attempting to remove the lithium coin battery.
    • Power off your AlphaSmart Pro device and remove the batteries before beginning disassembly.
    • Remove the eight 1 cm Phillips head screws from the back panel of the AlphaSmart Pro with the Phillips #00 Screwdriver.
    • Carefully separate the front panel from the back panel.
    • Notice that the front and back panels are still connected by a ribbon cable.
  2. AlphaSmart Pro Lithium Coin Battery Replacement, Detaching Ribbon Cable: stap 2, afbeelding 1 van 2 AlphaSmart Pro Lithium Coin Battery Replacement, Detaching Ribbon Cable: stap 2, afbeelding 2 van 2
    • To remove the ribbon cable, use the spudger to lift each side of the connector from the socket.
    • Gently pull up on the connector to completely remove the connector from the socket.
  3. AlphaSmart Pro Lithium Coin Battery Replacement, Locate Lithium Coin Battery: stap 3, afbeelding 1 van 2 AlphaSmart Pro Lithium Coin Battery Replacement, Locate Lithium Coin Battery: stap 3, afbeelding 2 van 2
    • With the front panel removed, locate the lithium coin battery at the top left corner of the motherboard.
  4. AlphaSmart Pro Lithium Coin Battery Replacement, Remove Lithium Coin Battery: stap 4, afbeelding 1 van 2 AlphaSmart Pro Lithium Coin Battery Replacement, Remove Lithium Coin Battery: stap 4, afbeelding 2 van 2
    • Use the spudger, plastic opening tool, or your finger/fingernail to lift up the lithium coin battery.
    • Slide the battery out from underneath the clip that holds it in place.
    • The positive side of the battery is facing up.
Conclusie
Katy Beth Culp
1 Reputatie
2 handleidingen geschreven
Clemson, Team 1-1, Benson Fall 2014 Lid van Clemson, Team 1-1, Benson Fall 2014
CLEM-BENSON-F14S1G1
4 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 15
Altijd: 867
