Ga door naar hoofdinhoud
Alldaymall A88X Battery Replacement
Wat je nodig hebt
  1. Alldaymall A88X Battery Replacement, Alldaymall A88X Back Cover: stap 1, afbeelding 1 van 3 Alldaymall A88X Battery Replacement, Alldaymall A88X Back Cover: stap 1, afbeelding 2 van 3 Alldaymall A88X Battery Replacement, Alldaymall A88X Back Cover: stap 1, afbeelding 3 van 3
    • Using a plastic opening tool, carefully pry the device apart. Make your way around the entire perimeter of the device and carefully place the two panels next to each other.
    • After the panels are separated, watch out for the speaker on the rear panel as it's wire is rather short.
    • When separating the panels keep an eye out for the power button and volume rocker as they can be dislodged.
  2. Alldaymall A88X Battery Replacement: stap 2, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Grip the speaker from the sides with your fingers or a pair of tweezers and slowly begin to remove it from the rear panel.
    • When removing the speaker, make sure not to disconnect the wires in any way.
    • After the speaker has been removed, place the rear panel aside.
  3. Alldaymall A88X Battery Replacement, Battery: stap 3, afbeelding 1 van 3 Alldaymall A88X Battery Replacement, Battery: stap 3, afbeelding 2 van 3 Alldaymall A88X Battery Replacement, Battery: stap 3, afbeelding 3 van 3
    • Carefully separate the speaker wire from the tape and proceed to peel the tape off in an upwards direction.
    • The tape we are removing covers a number of connections on the motherboard. Be extra careful not to server any of these.
  4. Alldaymall A88X Battery Replacement: stap 4, afbeelding 1 van 3 Alldaymall A88X Battery Replacement: stap 4, afbeelding 2 van 3 Alldaymall A88X Battery Replacement: stap 4, afbeelding 3 van 3
    • Using a nylon spudger, slowly work your way underneath the battery separating it from the panel beneath.
    • After the battery is separated from the panel make sure to place it face down above the tablet itself.
    • Throughout the removal process keep an eye on the battery's wires and make sure they do not break.
  5. Alldaymall A88X Battery Replacement: stap 5, afbeelding 1 van 2 Alldaymall A88X Battery Replacement: stap 5, afbeelding 2 van 2
    • Desolder the wires that connect the battery to the motherboard.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Alex
101 Reputatie
1 Handleiding geschreven
USF Tampa, Team 4-1, Lacy Spring 2016 Lid van USF Tampa, Team 4-1, Lacy Spring 2016
USFT-LACY-S16S4G1
4 Leden
16 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 1,217
