Ga door naar hoofdinhoud
Alienware m15 R6 Memory module Replacement
Wat je nodig hebt
  1. Alienware m15 R6 Memory module Replacement, Base Cover: stap 1, afbeelding 1 van 1
    • Remove the two screws (M2.5x5) that secure the base cover to the palm-rest and keyboard assembly.
    • New line. Loosen the two captive screws (M2.5x8.5+3.5) that secure the base cover to the palm-rest and keyboard assembly
    • Loosen the four captive screws (M2.5x1.7+3.3) that secure the base cover to the palm-rest and keyboard assembly.
  2. Alienware m15 R6 Memory module Replacement: stap 2, afbeelding 1 van 1
    • Using your fingertips, pry open the base cover from the middle of the front edge of base cover, and then pry the left and right sides of the base cover.
    • Lift the base cover off the palm-rest and keyboard assembly.
  3. Alienware m15 R6 Memory module Replacement: stap 3, afbeelding 1 van 1
    • Disconnect the battery cable from the system board.
    • Turn your computer over and press the power button for 20 seconds to drain the flea power
  4. Alienware m15 R6 Memory module Replacement, Memory module: stap 4, afbeelding 1 van 1
    • Lift the system board Mylar to access the memory module.
    • Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory modulepops up.
    • Remove the memory module from the memory-module slot.
Conclusie
Andrzej
1.702 Reputatie
18 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 13
Altijd: 289
