Ga door naar hoofdinhoud
Alienware X51 Heatsink Replacement
Wat je nodig hebt
  1. Alienware X51 Heatsink Replacement, Front Panel: stap 1, afbeelding 1 van 1
    • Place the PC so the name "Alienware" is on top and facing you.
    • Slide the front panel towards you and lift up.
  2. Alienware X51 Heatsink Replacement: stap 2, afbeelding 1 van 1
    • Fully disconnect the panel by unplugging the lighting cord going into the PC's internal system.
    • Remove the front panel from the rest of the device.
  3. Alienware X51 Heatsink Replacement, Fan: stap 3, afbeelding 1 van 2 Alienware X51 Heatsink Replacement, Fan: stap 3, afbeelding 2 van 2
    • Remove the two 2.0 mm screws holding the fan protector in place using a Phillips #1 screwdriver.
    • Remove the protector holding the fan in.
  4. Alienware X51 Heatsink Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the Molex KK connector from the fan.
  5. Alienware X51 Heatsink Replacement: stap 5, afbeelding 1 van 3 Alienware X51 Heatsink Replacement: stap 5, afbeelding 2 van 3 Alienware X51 Heatsink Replacement: stap 5, afbeelding 3 van 3
    • Use a Phillips #1 screwdriver to loosen the four spring screws around the fan until you hear a click.
    • Gently pull back the clips and remove the fan by pulling it out.
  6. Alienware X51 Heatsink Replacement, Heatsink: stap 6, afbeelding 1 van 3 Alienware X51 Heatsink Replacement, Heatsink: stap 6, afbeelding 2 van 3 Alienware X51 Heatsink Replacement, Heatsink: stap 6, afbeelding 3 van 3
    • Loosen the four 10.0 mm screws around the heatsink with a Phillips #1 screwdriver until you hear a click.
    • These are captive screws and cannot be fully removed.
    • Remove the heatsink by gently prying and lifting it up.
Conclusie
alondra
123 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 12
Altijd: 128
