Ga door naar hoofdinhoud
Alienware P18G M14X R1 Hard Drive Replacement
Wat je nodig hebt
  1. Alienware P18G M14X R1 Hard Drive Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Loosen the top left and top right 6.5mm PH1 screws that hold down the back cover.
    • The screws will not be able to be removed from the back cover. They can only be loosened or tightened.
  2. Alienware P18G M14X R1 Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Slide back cover forward using your thumbs.
  3. Alienware P18G M14X R1 Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • Lift up the cover and set aside exposing the internals of the computer.
  4. Alienware P18G M14X R1 Hard Drive Replacement, Battery: stap 4, afbeelding 1 van 1
    • Make sure the laptop is turned off before starting.
    • Using PH1 screwdriver loosen the two screws on the right of the battery.
    • The screws will not be able to be removed from the battery. They can only be loosened or tightened.
  5. Alienware P18G M14X R1 Hard Drive Replacement: stap 5, afbeelding 1 van 2 Alienware P18G M14X R1 Hard Drive Replacement: stap 5, afbeelding 2 van 2
    • Pull battery up using the tab provided.
  6. Alienware P18G M14X R1 Hard Drive Replacement: stap 6, afbeelding 1 van 1
    • Disconnect the clip connecting the battery to the computer.
    • Set battery aside.
  7. Alienware P18G M14X R1 Hard Drive Replacement, Optical Drive: stap 7, afbeelding 1 van 1
    • Unscrew the four 6.35mm screws using the PH1, that hold down the optical drive.
  8. Alienware P18G M14X R1 Hard Drive Replacement: stap 8, afbeelding 1 van 1
    • Using the plastic opening tool unclip the white connector holding down the orange cable.
  9. Alienware P18G M14X R1 Hard Drive Replacement: stap 9, afbeelding 1 van 1
    • Using the tab on the optical drive, lift the optical drive out of the computer and set it aside.
  10. Alienware P18G M14X R1 Hard Drive Replacement, Hard Drive: stap 10, afbeelding 1 van 1
    • Loosen the three 6.35 mm screws using the PH1 screw driver, to release the hard drive.
    • The screws will not be able to be removed from the hard drive. They can only be loosened or tightened.
  11. Alienware P18G M14X R1 Hard Drive Replacement: stap 11, afbeelding 1 van 1
    • Pull the tab on the hard drive slowly and carefuly because there will be a cable attached to it.
  12. Alienware P18G M14X R1 Hard Drive Replacement: stap 12, afbeelding 1 van 1
    • Pull the clip away from the hard drive to remove it.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Andonaq Grozdani
892 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S2-G2, Simcock Spring 2018 Lid van UMass Dartmouth, Team S2-G2, Simcock Spring 2018
UMASSD-SIMCOCK-S18S2G2
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 29
Altijd: 2,920
