Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Press down on the battery latch and slide it to the left.
Lift the battery out once it pops out.
Use your hand to gently lift and remove the compartment door.
Remove the Phillips #1 screw holding the plate.
Use your hand to remove the plate.
Pull the clips to the side away from each other. The RAM will pop up.
Lift forward and gently loosen to pull out of socket.
For the second RAM card use the opening tool to gently lift the RAM card forward.
