Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
Is your computer not loading application properly? Consider using this guide to replace the RAM in your laptop.
Onderdelen
Geen onderdelen opgegeven.
  1. Please power off the computer and deplete the battery before attempting the following step.
    • Please power off the computer and deplete the battery before attempting the following step.
  2. Press down on the battery latch and slide it to the left. Lift the battery out once it pops out.
    • Press down on the battery latch and slide it to the left.
    • Lift the battery out once it pops out.
  3. Loosen the two silver Phillips #1 screws.
    • Loosen the two silver Phillips #1 screws.
    • The screws are held to the compartment door by a washer and cannot be removed.
  4. SLA DE UPGRADE OVER
    Bespaar door het te repareren met een alles-in-één kit.
    Koop iPhone-reparatiekits
    SLA DE UPGRADE OVER
  5. Use your hand to gently lift and remove the compartment door. Use your hand to gently lift and remove the compartment door.
    • Use your hand to gently lift and remove the compartment door.
  6. Remove the Phillips #1 screw holding the plate. Use your hand to remove the plate.
    • Remove the Phillips #1 screw holding the plate.
    • Use your hand to remove the plate.
    • The screw is held to the plate by a washer and cannot be removed.
  7. Pull the clips to the side away from each other. The RAM will pop up. Lift forward and gently loosen to pull out of socket.
    • Pull the clips to the side away from each other. The RAM will pop up.
    • Lift forward and gently loosen to pull out of socket.
  8. For the second RAM card use the opening tool to gently lift the RAM card forward.
    • For the second RAM card use the opening tool to gently lift the RAM card forward.
Conclusie
Jose
306 Reputatie
3 handleidingen geschreven
CSU Fullerton, Team S2-G2, Bruce Fall 2018 Lid van CSU Fullerton, Team S2-G2, Bruce Fall 2018
CSUF-BRUCE-F18S2G2
4 Leden
8 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 295
