Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
If your laptop is incapable of performing routine tasks or recognizing when USB devices are plugged in, use this guide to remove and replace your motherboard.
Wat je nodig hebt
Remove the following screws using a Phillips #0 screwdriver to free the motherboard from the rest of the internal components.
Twelve 5.5 mm Phillips #0 main frame screws.
Six 3.5 mm Phillips #0 fan screws.
Four 3.5 mm Phillips #0 internal compartment screws.
Eight 3.5 mm Phillips #0 Hard Drive screws.
Four 3.5 mm Phillips #0 CD Drive screws.
