Inleiding
In this guide, we will show you how to remove and replace the Status-Light Board.
Wat je nodig hebt
Turn the computer off.
Disconnect the charging cable from the computer.
Flip the computer upside down.
Note the routing of status-light board cable and remove the cable from the routing guides.
Remove the screw that secures the status-light board to the palm-rest assembly.
Carefully lift the status-light board and release its cable from the slot on the palm-rest assembly.
Slide the NEW status-light board cable through the slot in the palm-rest assembly.
Align the slot on the status-light board with the alignment post on the palm-rest assembly.
Replace the screw that secures the status-light board to the palm-rest assembly.
Route the status-light board cable through the routing guides on the palm-rest assembly.
