Ga door naar hoofdinhoud
Alienware M14xR2 Battery Replacement
Wat je nodig hebt
  1. Alienware M14xR2 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in electric shock and serious injury.
    • Flip the computer upside down.
  2. Alienware M14xR2 Battery Replacement: stap 2, afbeelding 1 van 3 Alienware M14xR2 Battery Replacement: stap 2, afbeelding 2 van 3 Alienware M14xR2 Battery Replacement: stap 2, afbeelding 3 van 3
    • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
    • The two screws are spring loaded and will not separate from the cover.
    • Slide the back cover towards you and then lift upwards to remove.
  3. Alienware M14xR2 Battery Replacement: stap 3, afbeelding 1 van 1
    • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
    • The two screws are clipped into the battery and will not detach.
  4. Alienware M14xR2 Battery Replacement: stap 4, afbeelding 1 van 3 Alienware M14xR2 Battery Replacement: stap 4, afbeelding 2 van 3 Alienware M14xR2 Battery Replacement: stap 4, afbeelding 3 van 3
    • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
    • Pull up on the white connector to disconnect it from the laptop.
    • The battery is now free to remove from the laptop and can be set aside.
Conclusie
10 andere personen hebben deze handleiding voltooid.
Connor Bovee
569 Reputatie
2 handleidingen geschreven
Cal Poly, Team 13-4, Forte Fall 2013 Lid van Cal Poly, Team 13-4, Forte Fall 2013
CPSU-FORTE-F13S13G4
5 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 12
Altijd: 10,758
