Ga door naar hoofdinhoud
Alienware M11xR3 Disassembly and Cleaning
Wat je nodig hebt
  1. Alienware M11xR3 Disassembly and Cleaning, Beginning (Parts, Tools and Laptop): stap 1, afbeelding 1 van 1
    • Welcome to the Alienware M11xR3 disassembly. Below, I will describe the necessary tools and steps to disassemble the Alienware M11xR3. This disassembly applies to all M11x, including the R1, R2, and R3.
    • Required tools:
    • 1x Phillips #1 and #00 Screwdriver
    • 1x Flathead Screwdriver
    • 1x Small Needle Nose Pliers or Tweezers
    • 1x Thermal Paste and Finger Stalls Optional: Small water balloons (to spread thermal paste without getting dirty)
    • 1x Anti-Static Mat
    • I highly recommended reading about static electricity and how it can damage electronic components.
  2. Alienware M11xR3 Disassembly and Cleaning, Remove back plate screws.: stap 2, afbeelding 1 van 2 Alienware M11xR3 Disassembly and Cleaning, Remove back plate screws.: stap 2, afbeelding 2 van 2
    • Gently flip over the laptop so that the bottom side is facing up.
    • Use a Phillips #1 screwdriver to remove the 8 screws securing the base-plate.
  3. Alienware M11xR3 Disassembly and Cleaning, Remove back plate.: stap 3, afbeelding 1 van 1
    • Lift the bottom cover and remove it.
  4. Alienware M11xR3 Disassembly and Cleaning, Unscrew and unplug battery.: stap 4, afbeelding 1 van 3 Alienware M11xR3 Disassembly and Cleaning, Unscrew and unplug battery.: stap 4, afbeelding 2 van 3 Alienware M11xR3 Disassembly and Cleaning, Unscrew and unplug battery.: stap 4, afbeelding 3 van 3
    • Remove the battery cable on the plate by pulling vertically.
    • Unscrew and remove the screws retaining the battery.
  5. Alienware M11xR3 Disassembly and Cleaning, Remove Battery.: stap 5, afbeelding 1 van 1
    • Remove the battery.
  6. Alienware M11xR3 Disassembly and Cleaning, Remove the HDD: stap 6, afbeelding 1 van 2 Alienware M11xR3 Disassembly and Cleaning, Remove the HDD: stap 6, afbeelding 2 van 2
    • Remove the hard drive mounting bracket by removing the three screws with the Phillips #1 screwdriver.
    • Pull out the hard drive by lifting up on the black tab.
  7. Alienware M11xR3 Disassembly and Cleaning, (Optional) Replace HDD: stap 7, afbeelding 1 van 3 Alienware M11xR3 Disassembly and Cleaning, (Optional) Replace HDD: stap 7, afbeelding 2 van 3 Alienware M11xR3 Disassembly and Cleaning, (Optional) Replace HDD: stap 7, afbeelding 3 van 3
    • In order to remove the hard drive from the mounting bracket, remove the four screws at each corner with the Phillips #1 screwdriver.
    • When installing a new hard drive, never forget to remove the SATA adapter before installation.
  8. Alienware M11xR3 Disassembly and Cleaning, Remove RAM: stap 8, afbeelding 1 van 3 Alienware M11xR3 Disassembly and Cleaning, Remove RAM: stap 8, afbeelding 2 van 3 Alienware M11xR3 Disassembly and Cleaning, Remove RAM: stap 8, afbeelding 3 van 3
    • Pull the tabs away from RAM.
    • Carefully pull the RAM module to remove.
    • Depending on the configuration that you have on your Alienware, there may be another RAM module.
    • If you want to upgrade your RAM please read the manual about which modules are compatible. Here are the RAM specs:
    • Number of Sockets: 2
    • Max memory: 16384 MB (16GB)
    • Memory Comments: PC3-10600 1333Mhz DDR3 SDRAM SO-DIMM 204-pin
  9. Alienware M11xR3 Disassembly and Cleaning, Remove WLAN module: stap 9, afbeelding 1 van 3 Alienware M11xR3 Disassembly and Cleaning, Remove WLAN module: stap 9, afbeelding 2 van 3 Alienware M11xR3 Disassembly and Cleaning, Remove WLAN module: stap 9, afbeelding 3 van 3
    • Depending on your Alienware configuration, it can have up to 3 aerial cables.
    • Remove the aerial cables vertically with Tweezers or Small Needle Nose Pliers.
    • Once the aerial cables are removed, extract the screws.
    • Remove the WLAN card.
    • On USA models, a WWAN card may be located near the WLAN card. Use the same process to remove it.
  10. Alienware M11xR3 Disassembly and Cleaning, Remove chassis and keyboard screws: stap 10, afbeelding 1 van 3 Alienware M11xR3 Disassembly and Cleaning, Remove chassis and keyboard screws: stap 10, afbeelding 2 van 3 Alienware M11xR3 Disassembly and Cleaning, Remove chassis and keyboard screws: stap 10, afbeelding 3 van 3
    • Remove the chassis screws using a Phillips #1 screwdriver.
    • Remove the keyboard screws using a Phillips #1 screwdriver.
  11. Alienware M11xR3 Disassembly and Cleaning, Remove the chassis screws: stap 11, afbeelding 1 van 3 Alienware M11xR3 Disassembly and Cleaning, Remove the chassis screws: stap 11, afbeelding 2 van 3 Alienware M11xR3 Disassembly and Cleaning, Remove the chassis screws: stap 11, afbeelding 3 van 3
    • Remove the chassis screws.
  12. Alienware M11xR3 Disassembly and Cleaning, Remove the bottom chassis screws: stap 12, afbeelding 1 van 2 Alienware M11xR3 Disassembly and Cleaning, Remove the bottom chassis screws: stap 12, afbeelding 2 van 2
    • Remove the bottom chassis screws.
  13. Alienware M11xR3 Disassembly and Cleaning: stap 13, afbeelding 1 van 2 Alienware M11xR3 Disassembly and Cleaning: stap 13, afbeelding 2 van 2
    • The screw marked with a yellow circle is near the hard drive bay.
  14. Alienware M11xR3 Disassembly and Cleaning, Remove the screws from the keyboard: stap 14, afbeelding 1 van 2 Alienware M11xR3 Disassembly and Cleaning, Remove the screws from the keyboard: stap 14, afbeelding 2 van 2
    • Remove the screws from the keyboard.
  15. Alienware M11xR3 Disassembly and Cleaning, Remove the cover: stap 15, afbeelding 1 van 3 Alienware M11xR3 Disassembly and Cleaning, Remove the cover: stap 15, afbeelding 2 van 3 Alienware M11xR3 Disassembly and Cleaning, Remove the cover: stap 15, afbeelding 3 van 3
    • Use a small flat screwdriver to carefully pry the cover from the chassis.
    • Next, use your finger as a lever to extract the cover. The cover has tabs that attach it to the chassis.
    • In the next step, I'll show you tab locations.
  16. Alienware M11xR3 Disassembly and Cleaning, Tab locations: stap 16, afbeelding 1 van 3 Alienware M11xR3 Disassembly and Cleaning, Tab locations: stap 16, afbeelding 2 van 3 Alienware M11xR3 Disassembly and Cleaning, Tab locations: stap 16, afbeelding 3 van 3
    • Clamping tabs
  17. Alienware M11xR3 Disassembly and Cleaning: stap 17, afbeelding 1 van 2 Alienware M11xR3 Disassembly and Cleaning: stap 17, afbeelding 2 van 2
    • Remove the two screws to release the keyboard.
    • Wait for the next step to remove the keyboard; there are bus data cables underneath the keyboard that must be removed first.
  18. Alienware M11xR3 Disassembly and Cleaning, Remove bus data cables (part 1): stap 18, afbeelding 1 van 3 Alienware M11xR3 Disassembly and Cleaning, Remove bus data cables (part 1): stap 18, afbeelding 2 van 3 Alienware M11xR3 Disassembly and Cleaning, Remove bus data cables (part 1): stap 18, afbeelding 3 van 3
    • There are 2 bus data cables.
    • The thin orange cable is the RGB led keyboard retro illumination.
    • Lift the tab to a vertical position to free the bus cable as shown.
  19. Alienware M11xR3 Disassembly and Cleaning, Remove bus data cables (part 2): stap 19, afbeelding 1 van 3 Alienware M11xR3 Disassembly and Cleaning, Remove bus data cables (part 2): stap 19, afbeelding 2 van 3 Alienware M11xR3 Disassembly and Cleaning, Remove bus data cables (part 2): stap 19, afbeelding 3 van 3
    • Free the keyboard bus data cable as you did for the RGB bus data cable.
    • Remove the keyboard to replace it; it has pressure points like the previous cover.
    • If the keyboard fails, the best option is to replace it for a new one.
  20. Alienware M11xR3 Disassembly and Cleaning, Remove more chassis screws: stap 20, afbeelding 1 van 3 Alienware M11xR3 Disassembly and Cleaning, Remove more chassis screws: stap 20, afbeelding 2 van 3 Alienware M11xR3 Disassembly and Cleaning, Remove more chassis screws: stap 20, afbeelding 3 van 3
    • Continue taking out the chassis by unscrewing the 3 shown screws.
    • First one to the left of the RGB bus data cable.
    • Second one at bottom near the touchpad.
    • Third one on the right edge of the laptop.
  21. Alienware M11xR3 Disassembly and Cleaning, Remove touchpad data bus cable: stap 21, afbeelding 1 van 3 Alienware M11xR3 Disassembly and Cleaning, Remove touchpad data bus cable: stap 21, afbeelding 2 van 3 Alienware M11xR3 Disassembly and Cleaning, Remove touchpad data bus cable: stap 21, afbeelding 3 van 3
    • Lift the tab to disconnect the touchpad data bus cable.
  22. Alienware M11xR3 Disassembly and Cleaning, Remove bus cable to Motherboard.: stap 22, afbeelding 1 van 3 Alienware M11xR3 Disassembly and Cleaning, Remove bus cable to Motherboard.: stap 22, afbeelding 2 van 3 Alienware M11xR3 Disassembly and Cleaning, Remove bus cable to Motherboard.: stap 22, afbeelding 3 van 3
    • Extract the bus cable with needle nose pliers by lifting the tab and pulling it away.
    • If your computer doesn't power on, then check to make sure this cable is plugged in.
    • Always lift tabs vertically to free cables.
  23. Alienware M11xR3 Disassembly and Cleaning: stap 23, afbeelding 1 van 3 Alienware M11xR3 Disassembly and Cleaning: stap 23, afbeelding 2 van 3 Alienware M11xR3 Disassembly and Cleaning: stap 23, afbeelding 3 van 3
    • Lift the case with your fingers, as shown in the pictures.
    • Don't remove the case yet. There is another cable on the upper left corner that must be removed to fully remove the case.
  24. Alienware M11xR3 Disassembly and Cleaning: stap 24, afbeelding 1 van 2 Alienware M11xR3 Disassembly and Cleaning: stap 24, afbeelding 2 van 2
    • This is the cable that I mentioned in the previous step.
    • Pull the cable out to the right to remove it.
  25. Alienware M11xR3 Disassembly and Cleaning: stap 25, afbeelding 1 van 2 Alienware M11xR3 Disassembly and Cleaning: stap 25, afbeelding 2 van 2
    • Here's a top and bottom view of the board with the power on switch and LED status.
  26. Alienware M11xR3 Disassembly and Cleaning: stap 26, afbeelding 1 van 1
    • And here's a bottom view of the touchpad.
  27. Alienware M11xR3 Disassembly and Cleaning, Removing the bluetooth card.: stap 27, afbeelding 1 van 2 Alienware M11xR3 Disassembly and Cleaning, Removing the bluetooth card.: stap 27, afbeelding 2 van 2
    • Remove the shown screw.
    • Pull the cable off.
  28. Alienware M11xR3 Disassembly and Cleaning, (Optional)  Remove the BIOS battery: stap 28, afbeelding 1 van 1
    • This is the BIOS battery for internal configuration and clock. If you have problems with it, remove it by disconnecting it from the motherboard.
  29. Alienware M11xR3 Disassembly and Cleaning: stap 29, afbeelding 1 van 3 Alienware M11xR3 Disassembly and Cleaning: stap 29, afbeelding 2 van 3 Alienware M11xR3 Disassembly and Cleaning: stap 29, afbeelding 3 van 3
    • Pull the speakers connector towards you and away from the I/O board, marked by a yellow square.
    • Remove the 3 screws and lift as you see in the picture
    • Move the board a little to the left while lifting to prevent damaging the two attached USB 3.0 ports.
  30. Alienware M11xR3 Disassembly and Cleaning, Removing the display connector.: stap 30, afbeelding 1 van 3 Alienware M11xR3 Disassembly and Cleaning, Removing the display connector.: stap 30, afbeelding 2 van 3 Alienware M11xR3 Disassembly and Cleaning, Removing the display connector.: stap 30, afbeelding 3 van 3
    • Remove the display connector by pulling vertically.
    • Lift using the plastic tab. See the image provided in this step.
  31. Alienware M11xR3 Disassembly and Cleaning, Removing the monitor mount: stap 31, afbeelding 1 van 3 Alienware M11xR3 Disassembly and Cleaning, Removing the monitor mount: stap 31, afbeelding 2 van 3 Alienware M11xR3 Disassembly and Cleaning, Removing the monitor mount: stap 31, afbeelding 3 van 3
    • Unscrew the screws in the correct order by using the numbers near the holes.
    • Make sure you are holding the monitor while unscrewing to prevent dropping and damaging the screen.
    • After that, you must see the next step to remove the WLAN aerials.
  32. Alienware M11xR3 Disassembly and Cleaning, Pull WLAN cable away with monitor: stap 32, afbeelding 1 van 2 Alienware M11xR3 Disassembly and Cleaning, Pull WLAN cable away with monitor: stap 32, afbeelding 2 van 2
    • The WLAN cable is the same as in step 9.
    • Pass the cable from the bottom of the laptop through the hole carefully.
    • Remember, depending on your Alienware configuration you may have 2 or 3 aerials. USA customers may also have the WWAN aerials
  33. Alienware M11xR3 Disassembly and Cleaning, Removing the motherboard.: stap 33, afbeelding 1 van 3 Alienware M11xR3 Disassembly and Cleaning, Removing the motherboard.: stap 33, afbeelding 2 van 3 Alienware M11xR3 Disassembly and Cleaning, Removing the motherboard.: stap 33, afbeelding 3 van 3
    • Remove the four screws, marked by red circles, to remove the motherboard.
    • Now lift the motherboard slowly up while moving it to the right. Removing it this way prevents damage to your ports.
    • As you see in the picture, the I/O board and screen connector wasn't here. They must be disconnected before removing the motherboard, not like the bluetooth board or coin-cell battery.
  34. Alienware M11xR3 Disassembly and Cleaning: stap 34, afbeelding 1 van 2 Alienware M11xR3 Disassembly and Cleaning: stap 34, afbeelding 2 van 2
    • Disconnect the vent connector.
    • You must disconnect it to remove the heatsink.
    • To replace the vent, it is not necessary to remove the heatsink. You must do this step and in the next step I have marked in green the 3 screws that you need to remove.
    • To maintain good ventilation, clean the vent with compressed air.
  35. Alienware M11xR3 Disassembly and Cleaning, Remove heat sink and apply thermal paste: stap 35, afbeelding 1 van 3 Alienware M11xR3 Disassembly and Cleaning, Remove heat sink and apply thermal paste: stap 35, afbeelding 2 van 3 Alienware M11xR3 Disassembly and Cleaning, Remove heat sink and apply thermal paste: stap 35, afbeelding 3 van 3
    • If this is your first time applying thermal paste, I recommend using a quality thermal paste brand like Arctic Silver and reading a guide here on iFixit.
    • With the motherboard out, turn it upside down on a static free surface.
    • To remove the heatsink and replace thermal paste, remove the screws in the correct order (marked with a number on the heatsink).
    • Clean old thermal paste with isopropyl alcohol. Ensure that after applying thermal paste it doesn't leak onto the motherboard (if it's on the green square, it's fine).
    • When putting the heat sink back on, try to have the screw holes align on your first try. This is to maintain an even spread of the thermal paste.
    • Rescrew in the correct order (refer to the numbers on the heat sink).
    • Tighten each screw one at a time to end up with good heat dissipation.
    On the topic of thermal paste, just put a line from one end of the cpu to the other, and it will be good
    Robo and Rainbow - Antwoord
Eindstreep
7 andere personen hebben deze handleiding voltooid.
AdrianP
442 Reputatie
1 Handleiding geschreven
2 opmerkingen
I needed to modify it so i t would work for my M11X R1
but after all, pretty goosd tutorial.
Szymon PlayZGameZ - Antwoord
Awesomely detailed, thank you :)
fraser - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 76
Altijd: 24,155
