Inleiding
How to remove and replace Coin-Cell Battery
Wat je nodig hebt
Loosen the eight captive screws that secure the base cover to the computer base.
Align the tabs on the NEW base cover with the slots on the computer base and place the base cover in position.
Tighten the eight screws that secure the base cover to the computer base.
Disconnect the coin-cell battery cable from the connector on the system board.
The coin-cell battery is glued to the system board. Using a plastic scribe, pry the coin-cell battery from the system board.
Use the adhesive on NEW the coin-cell battery and adhere it to the system board.
Connect the coin-cell battery cable to the connector on the system board.
3 andere personen hebben deze handleiding voltooid.
