Ga door naar hoofdinhoud
Alienware M11xR2 Coin-Cell Battery Replacement
Wat je nodig hebt
  1. Alienware M11xR2 Coin-Cell Battery Replacement, Removing the Base Cover: stap 1, afbeelding 1 van 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Turn the computer over.
  2. Alienware M11xR2 Coin-Cell Battery Replacement, Loosen the Screws: stap 2, afbeelding 1 van 1
    • Loosen the eight captive screws that secure the base cover to the computer base.
  3. Alienware M11xR2 Coin-Cell Battery Replacement, Lifting the Base Cover: stap 3, afbeelding 1 van 1
    • Lift the base cover off the computer base.
  4. Alienware M11xR2 Coin-Cell Battery Replacement, Replacing the Base Cover: stap 4, afbeelding 1 van 1
    • Align the tabs on the NEW base cover with the slots on the computer base and place the base cover in position.
  5. Alienware M11xR2 Coin-Cell Battery Replacement, Securing the Screws: stap 5, afbeelding 1 van 1
    • Tighten the eight screws that secure the base cover to the computer base.
  6. Alienware M11xR2 Coin-Cell Battery Replacement, Disconnecting Coin-Cell Battery: stap 6, afbeelding 1 van 1
    • Disconnect the coin-cell battery cable from the connector on the system board.
  7. Alienware M11xR2 Coin-Cell Battery Replacement, Prying The Coin-Cell Battery: stap 7, afbeelding 1 van 1
    • The coin-cell battery is glued to the system board. Using a plastic scribe, pry the coin-cell battery from the system board.
  8. Alienware M11xR2 Coin-Cell Battery Replacement, Placing New Coin-Cell Battery: stap 8, afbeelding 1 van 1
    • Use the adhesive on NEW the coin-cell battery and adhere it to the system board.
  9. Alienware M11xR2 Coin-Cell Battery Replacement, Connecting Cable: stap 9, afbeelding 1 van 1
    • Connect the coin-cell battery cable to the connector on the system board.
Conclusie
3 andere personen hebben deze handleiding voltooid.
darrius
5.213 Reputatie
30 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
42 Leden
1.985 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 404
