Ga door naar hoofdinhoud
Alienware M11xR2 Base Cover Replacement
Wat je nodig hebt
  1. Alienware M11xR2 Base Cover Replacement, Removing the Base Cover: stap 1, afbeelding 1 van 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Turn the computer over.
  2. Alienware M11xR2 Base Cover Replacement, Loosen the Screws: stap 2, afbeelding 1 van 1
    • Loosen the eight captive screws that secure the base cover to the computer base.
  3. Alienware M11xR2 Base Cover Replacement, Lifting the Base Cover: stap 3, afbeelding 1 van 1
    • Lift the base cover off the computer base.
  4. Alienware M11xR2 Base Cover Replacement, Replacing the Base Cover: stap 4, afbeelding 1 van 1
    • Align the tabs on the NEW base cover with the slots on the computer base and place the base cover in position.
  5. Alienware M11xR2 Base Cover Replacement, Securing the Screws: stap 5, afbeelding 1 van 1
    • Tighten the eight screws that secure the base cover to the computer base.
Eindstreep
darrius
5.213 Reputatie
30 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
42 Leden
1.984 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 272
