Ga door naar hoofdinhoud
Alienware M11x Memory Module Replacement
Wat je nodig hebt
  1. Alienware M11x Memory Module Replacement, Introduction: stap 1, afbeelding 1 van 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    Vraag FixBot
  2. Alienware M11x Memory Module Replacement, Removing the Memory Module: stap 2, afbeelding 1 van 1
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
    Vraag FixBot
  3. Alienware M11x Memory Module Replacement, Removing the Memory Module: stap 3, afbeelding 1 van 2 Alienware M11x Memory Module Replacement, Removing the Memory Module: stap 3, afbeelding 2 van 2
    • Remove the memory module from the memory module connector.
    Vraag FixBot
  4. Alienware M11x Memory Module Replacement, Replacing the Memory Module: stap 4, afbeelding 1 van 1
    • NOTE: If you need to install memory modules in two connectors, install a memory module in the lower connector before you install a module in the upper connector
    • Align the notch in the NEW memory module with the tab in the memory module connector.
    Vraag FixBot
  5. Alienware M11x Memory Module Replacement, Installing the Memory Module: stap 5, afbeelding 1 van 1
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
    Vraag FixBot
Eindstreep
darrius
5.213 Reputatie
30 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
45 Leden
2.002 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 85
Altijd: 709
