Ga door naar hoofdinhoud
Alienware Aurora M9700 Hard Drive Replacement
Wat je nodig hebt
  1. Alienware Aurora M9700 Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 1
    • Turn laptop upside down so you're looking at the bottom side of the laptop.
  2. Alienware Aurora M9700 Hard Drive Replacement: stap 2, afbeelding 1 van 3 Alienware Aurora M9700 Hard Drive Replacement: stap 2, afbeelding 2 van 3 Alienware Aurora M9700 Hard Drive Replacement: stap 2, afbeelding 3 van 3
    • At the bottom left corner, locate the square battery pack with the sliding unlock emblem above it.
    • Slide the lock to the right to unlock the battery pack.
    • Once it's unlocked the battery will release.
    • Lift the battery, removing it from its compartment.
  3. Alienware Aurora M9700 Hard Drive Replacement: stap 3, afbeelding 1 van 3 Alienware Aurora M9700 Hard Drive Replacement: stap 3, afbeelding 2 van 3 Alienware Aurora M9700 Hard Drive Replacement: stap 3, afbeelding 3 van 3
    • At the bottom right corner, locate the two hard drives labeled 1 and 2.
    • Remove the screws located on top of the hard drives slots.
    • Once screws are removed from each hard drive, slide both hard drives out of the slot.
  4. Alienware Aurora M9700 Hard Drive Replacement: stap 4, afbeelding 1 van 3 Alienware Aurora M9700 Hard Drive Replacement: stap 4, afbeelding 2 van 3 Alienware Aurora M9700 Hard Drive Replacement: stap 4, afbeelding 3 van 3
    • Each hard drive is attached to a cover which contains 4 screws located on all 4 corners of the hard drive.
    • Remove each of the 4 screws on both hard drive covers.
    • Once both covers are removed only the original hard drive will remain.
  5. Alienware Aurora M9700 Hard Drive Replacement: stap 5, afbeelding 1 van 3 Alienware Aurora M9700 Hard Drive Replacement: stap 5, afbeelding 2 van 3 Alienware Aurora M9700 Hard Drive Replacement: stap 5, afbeelding 3 van 3
    • Secure the new hard drive to the original hard drive cover, insert the screws on all 4 corners of the hard drive cover.
    • Complete this process for both hard drives. (Optional: if installing two drives.)
Conclusie
Jasmine Anchondo
679 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 16
Altijd: 431
