Ga door naar hoofdinhoud
Alienware Aurora M9700 Camera Replacement
Wat je nodig hebt
  1. Alienware Aurora M9700 Camera Replacement, Camera: stap 1, afbeelding 1 van 1
    • Open the device so the main screen is facing forward.
    • Locate the 8 rubber buttons around the bezel of the display and remove the rubber buttons with the metal spudger to expose the screws underneath.
    • Locate the 8 screws around the perimeter of the screen and unscrew them.
  2. Alienware Aurora M9700 Camera Replacement: stap 2, afbeelding 1 van 2 Alienware Aurora M9700 Camera Replacement: stap 2, afbeelding 2 van 2
    • Insert the plastic opening tool between the black and green frames to remove the display frame at the bottom of the display.
    • Slide the lock to the right when removing the display frame.
    • Remove the frame display.
  3. Alienware Aurora M9700 Camera Replacement: stap 3, afbeelding 1 van 2 Alienware Aurora M9700 Camera Replacement: stap 3, afbeelding 2 van 2
    • Now that the outer frame is removed, locate the two screws to the right and the left of the camera.
    • Remove the two screws freeing the camera of the brackets holding it in place.
    • Pry the camera upward from its designated location using the metal spudger.
  4. Alienware Aurora M9700 Camera Replacement: stap 4, afbeelding 1 van 2 Alienware Aurora M9700 Camera Replacement: stap 4, afbeelding 2 van 2
    • Unplug the wire connection between the camera and the laptop.
Conclusie
Jasmine Anchondo
679 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 16
Altijd: 196
