Ga door naar hoofdinhoud
Alienware 17 R4 Wi-Fi Card Replacement
Wat je nodig hebt
  1. Alienware 17 R4 Wi-Fi Card Replacement, Base Cover: stap 1, afbeelding 1 van 1
    • Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
    • Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
    • The M2x3 screw (1.9 mm) does not come out completely.
  2. Alienware 17 R4 Wi-Fi Card Replacement: stap 2, afbeelding 1 van 2 Alienware 17 R4 Wi-Fi Card Replacement: stap 2, afbeelding 2 van 2
    • Pull the base cover up to remove it.
    • If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
    • Removing the cover may require some force.
  3. Alienware 17 R4 Wi-Fi Card Replacement, Wi-Fi card: stap 3, afbeelding 1 van 1
    • Locate the WI-FI card.
  4. Alienware 17 R4 Wi-Fi Card Replacement: stap 4, afbeelding 1 van 2 Alienware 17 R4 Wi-Fi Card Replacement: stap 4, afbeelding 2 van 2
    • Peel back plastic cover of wi-fi card.
    • Use a PH1 screwdriver bit and remove the one M2x3 screw (1.9 mm)
  5. Alienware 17 R4 Wi-Fi Card Replacement: stap 5, afbeelding 1 van 3 Alienware 17 R4 Wi-Fi Card Replacement: stap 5, afbeelding 2 van 3 Alienware 17 R4 Wi-Fi Card Replacement: stap 5, afbeelding 3 van 3
    • Gently undo the clips attached to the wi-fi card.
    • If the clip is not gently removed it is possible that the entire base will be torn off the wi-fi card. You will need to purchase a new wi-fi card if this occurs.
  6. Alienware 17 R4 Wi-Fi Card Replacement: stap 6, afbeelding 1 van 2 Alienware 17 R4 Wi-Fi Card Replacement: stap 6, afbeelding 2 van 2
    • Locate the cables that connect the wi-fi card.
    • Gently pull upwards to remove cables and slide the wi-fi card out from its slot.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Hector Mendez III
1.280 Reputatie
8 handleidingen geschreven
CSU Fullerton, Team S2-G4, Bruce Fall 2017 Lid van CSU Fullerton, Team S2-G4, Bruce Fall 2017
CSUF-BRUCE-F17S2G4
4 Leden
9 handleidingen geschreven
Één opmerking
What is the logic for removing the HHD prior to removing the WIFI card?
Roderick Vanderzalm - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 41
Altijd: 4,592
