Ga door naar hoofdinhoud
Alienware 17 R4 Hard Disk Drive (HDD) Replacement
Wat je nodig hebt
  1. Alienware 17 R4 Hard Disk Drive (HDD) Replacement, Base Cover: stap 1, afbeelding 1 van 1
    • Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
    • Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
    • The M2x3 screw (1.9 mm) does not come out completely.
  2. Alienware 17 R4 Hard Disk Drive (HDD) Replacement: stap 2, afbeelding 1 van 2 Alienware 17 R4 Hard Disk Drive (HDD) Replacement: stap 2, afbeelding 2 van 2
    • Pull the base cover up to remove it.
    • If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
    • Removing the cover may require some force.
  3. Alienware 17 R4 Hard Disk Drive (HDD) Replacement, Hard Disk Drive (HDD): stap 3, afbeelding 1 van 3 Alienware 17 R4 Hard Disk Drive (HDD) Replacement, Hard Disk Drive (HDD): stap 3, afbeelding 2 van 3 Alienware 17 R4 Hard Disk Drive (HDD) Replacement, Hard Disk Drive (HDD): stap 3, afbeelding 3 van 3
    • Disconnect the battery connector cable, located on the right side of the laptop, above the hard disk drive.
    • Once you have removed the cable, wait 5-10 minutes to allow the laptop to power down.
    • Failure to remove the battery connector cable properly may damage other parts of the laptop.
  4. Alienware 17 R4 Hard Disk Drive (HDD) Replacement: stap 4, afbeelding 1 van 3 Alienware 17 R4 Hard Disk Drive (HDD) Replacement: stap 4, afbeelding 2 van 3 Alienware 17 R4 Hard Disk Drive (HDD) Replacement: stap 4, afbeelding 3 van 3
    • Use a PH1 screwdriver bit to remove the four M2.5x5 screws (2.4 mm) on the hard disk drive.
  5. Alienware 17 R4 Hard Disk Drive (HDD) Replacement: stap 5, afbeelding 1 van 3 Alienware 17 R4 Hard Disk Drive (HDD) Replacement: stap 5, afbeelding 2 van 3 Alienware 17 R4 Hard Disk Drive (HDD) Replacement: stap 5, afbeelding 3 van 3
    • Gently lift the HDD cable to disconnect it from the laptop.
  6. Alienware 17 R4 Hard Disk Drive (HDD) Replacement: stap 6, afbeelding 1 van 2 Alienware 17 R4 Hard Disk Drive (HDD) Replacement: stap 6, afbeelding 2 van 2
    • Pull the hard drive up to remove.
Conclusie
Hector Mendez III
1.280 Reputatie
8 handleidingen geschreven
CSU Fullerton, Team S2-G4, Bruce Fall 2017 Lid van CSU Fullerton, Team S2-G4, Bruce Fall 2017
CSUF-BRUCE-F17S2G4
4 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 57
Altijd: 6,359
