Ga door naar hoofdinhoud
Alienware 17 R2 Screen Replacement
Wat je nodig hebt
  1. Alienware 17 R2  Screen Replacement, Display: stap 1, afbeelding 1 van 1
    • Put the laptop on a hard surface.
    • Make sure that the Alienware is not plugged into any power source.
    • First, we need to unplug the battery.
  2. Alienware 17 R2  Screen Replacement: stap 2, afbeelding 1 van 2 Alienware 17 R2  Screen Replacement: stap 2, afbeelding 2 van 2
    • To unplug the battery, turn the computer upside down.
    • Remove the two 4mm screws from the plastic covering protecting the inner part of the laptop.
  3. Alienware 17 R2  Screen Replacement: stap 3, afbeelding 1 van 2 Alienware 17 R2  Screen Replacement: stap 3, afbeelding 2 van 2
    • Gently, pull the cover up and slide it off.
  4. Alienware 17 R2  Screen Replacement: stap 4, afbeelding 1 van 3 Alienware 17 R2  Screen Replacement: stap 4, afbeelding 2 van 3 Alienware 17 R2  Screen Replacement: stap 4, afbeelding 3 van 3
    • Now, you are going to look for a yellow tag.
    • Unplug the black wire that has the yellow tag.
    • This with successfully disconnect your battery.
  5. Alienware 17 R2  Screen Replacement: stap 5, afbeelding 1 van 2 Alienware 17 R2  Screen Replacement: stap 5, afbeelding 2 van 2
    • Using the plastic opening tool, gently remove the black plastic casing from the LCD screen.
    • Run the opening tool along the inner side of the computer where the screen and the plastic covering meet.
  6. Alienware 17 R2  Screen Replacement: stap 6, afbeelding 1 van 1
    • No you will unscrew the 2mm screws on the top and bottom side of the screen.
  7. Alienware 17 R2  Screen Replacement: stap 7, afbeelding 1 van 1
    • Tilt the screen forward towards the keyboard.
    • Disconnect the plug that is connecting the screen to the main body.
  8. Alienware 17 R2  Screen Replacement: stap 8, afbeelding 1 van 1
    • Gently, lift the display away from the laptop.
Conclusie
Luis Garcia
402 Reputatie
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 16
Altijd: 3,357
