Ga door naar hoofdinhoud
Alienware 15 R2 RAM Replacement
Wat je nodig hebt
  1. Alienware 15 R2 RAM Replacement, RAM: stap 1, afbeelding 1 van 3 Alienware 15 R2 RAM Replacement, RAM: stap 1, afbeelding 2 van 3 Alienware 15 R2 RAM Replacement, RAM: stap 1, afbeelding 3 van 3
    • Place laptop upside down with the hinge facing you, then remove the two 9mm Phillips #0 screws located in the bottom left and right of the of the rear panel.
    • Remove the rear panel by using the iFixit opening tool to separate it from the back of the laptop.
  2. Alienware 15 R2 RAM Replacement: stap 2, afbeelding 1 van 2 Alienware 15 R2 RAM Replacement: stap 2, afbeelding 2 van 2
    • Use the iFixit opening tool to disconnect the battery cable. Put the iFixit tool underneath the cable and then pull it to remove.
  3. Alienware 15 R2 RAM Replacement: stap 3, afbeelding 1 van 2 Alienware 15 R2 RAM Replacement: stap 3, afbeelding 2 van 2
    • Find the RAM located near the edge of the computer closest to you. Locate the small latches on either side of the RAM stick and push in the two latches to release. Gently grasp the RAM stick on either side and pull straight out. Repeat for the second RAM stick.
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 63
Altijd: 2,639
