Inleiding
If your device is not displaying picture or has a cracked screen, this will show you how to replace the display panel and/or digitizer. Due to the way the display panel and digitizer are connected, this guide can show you the steps to replace both pieces.
Wat je nodig hebt
Begin working by using the plastic opening tool to remove the back cover of your Alcatel One Touch Pop 7. Opening the flap as shown in the picture will give you an easier start.
Pull the copper ribbon cable from the tab. It should be easily removed, as the ZIF connector is the only thing holding it in place.
Next up is removing the volume button assembly. Another easy removal, simply pull the assembly away from the device and you're done with the removal process.
The camera is in the top left corner of the tablet. To begin removal, use the tweezers to gently disconnect the ribbon cable attached to the camera.
We now need to remove 3 ZIF connectors, all located in the bottom right quadrant. The order they are disconnected doesn't matter.
Using a PH00 screwdriver, remove the 6 highlighted 2mm screws.
Pull the ribbon cables away from the back of the display screen. The right cable can be removed completely while the left will stay attached to the front casing.
4 andere personen hebben deze handleiding voltooid.
Één opmerking
Hi please I will like to ask weather you have the screen in stock...am from Ghana... kindly hit me back on jamessalia11@gmail.com
Will be glad to hear from you
