Ga door naar hoofdinhoud
Alcatel One Touch Idol 3 Battery Replacement
Wat je nodig hebt
  1. Alcatel One Touch Idol 3 Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Alcatel One Touch Idol 3 Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Alcatel One Touch Idol 3 Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Remove the sim tray by inserting a sim removal tool and then pulling it out.
  2. Alcatel One Touch Idol 3 Battery Replacement: stap 2, afbeelding 1 van 3 Alcatel One Touch Idol 3 Battery Replacement: stap 2, afbeelding 2 van 3 Alcatel One Touch Idol 3 Battery Replacement: stap 2, afbeelding 3 van 3
    • Remove the back cover by moving around its perimeter with a thin object that can fit.
    • Eventually you will be able to pry open the back cover.
    • Although a razor is depicted, we recommend using ESD-safe pry tools instead.
  3. Alcatel One Touch Idol 3 Battery Replacement: stap 3, afbeelding 1 van 2 Alcatel One Touch Idol 3 Battery Replacement: stap 3, afbeelding 2 van 2
    • Remove the protective sticker from the battery connection.
  4. Alcatel One Touch Idol 3 Battery Replacement: stap 4, afbeelding 1 van 2 Alcatel One Touch Idol 3 Battery Replacement: stap 4, afbeelding 2 van 2
    • Disconnect the battery's connection to the motherboard by lifting it upwards.
  5. Alcatel One Touch Idol 3 Battery Replacement: stap 5, afbeelding 1 van 2 Alcatel One Touch Idol 3 Battery Replacement: stap 5, afbeelding 2 van 2
    • Add a small amount of isopropyl alcohol around the sides of the battery to soften the adhesive.
    • Take care to not get isopropyl alcohol on any other parts of the phone.
  6. Alcatel One Touch Idol 3 Battery Replacement: stap 6, afbeelding 1 van 3 Alcatel One Touch Idol 3 Battery Replacement: stap 6, afbeelding 2 van 3 Alcatel One Touch Idol 3 Battery Replacement: stap 6, afbeelding 3 van 3
    • Pry out the battery by leveraging an object under the battery and lifting it upwards.
    • Although a razor is depicted, we recommend using ESD-safe pry tools instead. A razor could easily puncture the battery and create a hazard.
Conclusie
Eric Lopez
133 Reputatie
1 Handleiding geschreven
CSU Los Angeles, Team 2-87, Briggs Fall 2023 Lid van CSU Los Angeles, Team 2-87, Briggs Fall 2023
CSULA-BRIGGS-F23S2G87
1 Lid
1 handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 186
