Ga door naar hoofdinhoud
Alcatel One Touch Fierce Front Facing Camera Replacement
Wat je nodig hebt
  1. Alcatel One Touch Fierce Front Facing Camera Replacement, Rear Case: stap 1, afbeelding 1 van 2 Alcatel One Touch Fierce Front Facing Camera Replacement, Rear Case: stap 1, afbeelding 2 van 2
    • Pry with a plastic opening tool, or your fingernail, in the divot at the bottom left corner of the phone.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Alcatel One Touch Fierce Front Facing Camera Replacement, Midframe: stap 2, afbeelding 1 van 3 Alcatel One Touch Fierce Front Facing Camera Replacement, Midframe: stap 2, afbeelding 2 van 3 Alcatel One Touch Fierce Front Facing Camera Replacement, Midframe: stap 2, afbeelding 3 van 3
    • Remove the 11 Phillips #000 screws.
    • The midframe should lift free.
  3. Alcatel One Touch Fierce Front Facing Camera Replacement, Battery: stap 3, afbeelding 1 van 2 Alcatel One Touch Fierce Front Facing Camera Replacement, Battery: stap 3, afbeelding 2 van 2
    • Use the tip of a spudger to pull back the yellow tape covering the battery connector.
    • Use a pair of tweezers to pull the battery connector from its port.
    • Be careful not to tear the battery from its connection.
  4. Alcatel One Touch Fierce Front Facing Camera Replacement, Camera: stap 4, afbeelding 1 van 1
    • Carefully remove the motherboard from the rest of the phone.
  5. Alcatel One Touch Fierce Front Facing Camera Replacement: stap 5, afbeelding 1 van 2 Alcatel One Touch Fierce Front Facing Camera Replacement: stap 5, afbeelding 2 van 2
    • Use a pair of tweezers to disconnect and remove the front facing camera from the motherboard.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Rijkaard Thomas
99 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 5-5, Vijaybhaskar Fall 2014 Lid van UMass Dartmouth, Team 5-5, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S5G5
3 Leden
6 handleidingen geschreven
2 opmerkingen
tenx tenx tenx !!?
ismail - Antwoord
I paid for a phone to capture precious moments, & the pictures are horrible, how can this be fixed??? This is wrong on all levels, I feel that we should be able to try any phone out before purchasing, so we know what we are buying, I'm returning my phone & wouldn't recommend this brand to anyone.
Jeanne Edenfield - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 6,501
