Ga door naar hoofdinhoud
Alcatel One Touch Evolve 2 Back Frame Replacement
Wat je nodig hebt
  1. Alcatel One Touch Evolve 2 Back Frame Replacement, Back Frame: stap 1, afbeelding 1 van 3 Alcatel One Touch Evolve 2 Back Frame Replacement, Back Frame: stap 1, afbeelding 2 van 3 Alcatel One Touch Evolve 2 Back Frame Replacement, Back Frame: stap 1, afbeelding 3 van 3
    • Turn off the phone before proceeding with disassembly to prevent shock and potential shorting of any electrical somponents.
    • Remove the back cover using one of the plastic opening tools and the slit in one of the corners.
    • Be gentle when prying so as to not wear out the tool.
  2. Alcatel One Touch Evolve 2 Back Frame Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery using one of the plastic opening tools and the dome-shaped indent next to the battery face.
  3. Alcatel One Touch Evolve 2 Back Frame Replacement: stap 3, afbeelding 1 van 1
    • Unscrew the four 4mm JIS screws in each corner using the J000 screwdriver head. Turn the screws counter-clockwise to loosen.
  4. Alcatel One Touch Evolve 2 Back Frame Replacement: stap 4, afbeelding 1 van 3 Alcatel One Touch Evolve 2 Back Frame Replacement: stap 4, afbeelding 2 van 3 Alcatel One Touch Evolve 2 Back Frame Replacement: stap 4, afbeelding 3 van 3
    • Insert a plastic or metal spudger between the front cover and rear frame in one of the areas indicated by the red squares and gently pry the rear frame loose. Repeat the process all the way around the phone until the rear frame comes loose.
  5. Alcatel One Touch Evolve 2 Back Frame Replacement: stap 5, afbeelding 1 van 2 Alcatel One Touch Evolve 2 Back Frame Replacement: stap 5, afbeelding 2 van 2
    • Pull the rear frame off with your hands.
Conclusie
Andrew Bai
634 Reputatie
5 handleidingen geschreven
IUPUI, Team 1-3, Baechle Spring 2017 Lid van IUPUI, Team 1-3, Baechle Spring 2017
IUPUI-BAECHLE-S17S1G3
4 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 25
Altijd: 1,085
