Ga door naar hoofdinhoud
Akko MOD 007 v2 Keyboard Switch Replacement
Wat je nodig hebt
  1. Akko MOD 007 v2 Keyboard Switch Replacement, Keyboard Switch: stap 1, afbeelding 1 van 2 Akko MOD 007 v2 Keyboard Switch Replacement, Keyboard Switch: stap 1, afbeelding 2 van 2
    • Unplug the USB-C cable.
  2. Akko MOD 007 v2 Keyboard Switch Replacement: stap 2, afbeelding 1 van 2 Akko MOD 007 v2 Keyboard Switch Replacement: stap 2, afbeelding 2 van 2
    • Flip the keyboard over so the backside is facing up.
    • Remove the three longer 20.2 mm screws using the T5 Torx screwdriver.
    • Remove the three 8 mm screws using the T5 Torx screwdriver.
  3. Akko MOD 007 v2 Keyboard Switch Replacement: stap 3, afbeelding 1 van 2 Akko MOD 007 v2 Keyboard Switch Replacement: stap 3, afbeelding 2 van 2
    • Pull the front and back case apart.
    • If your keyboard is dirty, you’ll want to clean it before continuing. Use compressed air or a brush.
  4. Akko MOD 007 v2 Keyboard Switch Replacement: stap 4, afbeelding 1 van 2 Akko MOD 007 v2 Keyboard Switch Replacement: stap 4, afbeelding 2 van 2
    • Insert the keycap puller horizontally on the keycap and pull up.
    • Excessive force may break the tool or keycaps so don't yank the keycap up.
  5. Akko MOD 007 v2 Keyboard Switch Replacement: stap 5, afbeelding 1 van 2 Akko MOD 007 v2 Keyboard Switch Replacement: stap 5, afbeelding 2 van 2
    • Insert the switch puller vertically in the switch tabs and gently pull up.
  6. Akko MOD 007 v2 Keyboard Switch Replacement: stap 6, afbeelding 1 van 3 Akko MOD 007 v2 Keyboard Switch Replacement: stap 6, afbeelding 2 van 3 Akko MOD 007 v2 Keyboard Switch Replacement: stap 6, afbeelding 3 van 3
    • Orientate the new switch to align the pins to the board's sockets.
    • Push the switch down into the sockets.
    • Make sure the pins are aligned to sockets, as misalignment will cause the switch to be faulty.
Conclusie
Test the switch by opening a keyboard tester website, like 'keyboardtester.com,' and press the key to see if it activates.
Farhan
133 Reputatie
1 Handleiding geschreven
York University, Team A-2, Morris Fall 2022 Lid van York University, Team A-2, Morris Fall 2022
YORK-MORRIS-F22SAG2
2 Leden
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 61
Altijd: 1,025
