Ga door naar hoofdinhoud
Akai MPC 4000 Pad Sensor Replacement
Wat je nodig hebt
  1. Akai MPC 4000 Pad Sensor Replacement, Side Panels: stap 1, afbeelding 1 van 2 Akai MPC 4000 Pad Sensor Replacement, Side Panels: stap 1, afbeelding 2 van 2
    • Using a #1 Phillips screwdriver, remove a total of (8) 7mm Phillips screws (4 on each side) and remove the panels.
  2. Akai MPC 4000 Pad Sensor Replacement, Wrist Rest: stap 2, afbeelding 1 van 1
    • Underneath the front of the device, remove (5) 8mm Phillips screws, flip the device back over and lift off the wrist rest.
  3. Akai MPC 4000 Pad Sensor Replacement, Cover Panel: stap 3, afbeelding 1 van 3 Akai MPC 4000 Pad Sensor Replacement, Cover Panel: stap 3, afbeelding 2 van 3 Akai MPC 4000 Pad Sensor Replacement, Cover Panel: stap 3, afbeelding 3 van 3
    • Remove the (13) 8mm Phillips screws on the top of the device.
    • Using a 3mm Hex screwdriver, remove the (4) 7mm Hex screws surrounding the pad.
    • Remove the (3) 8mm Phillips screws on the back of the device.
    • Remove the (1) 8mm Phillips screw underneath the front of the device.
  4. Akai MPC 4000 Pad Sensor Replacement: stap 4, afbeelding 1 van 2 Akai MPC 4000 Pad Sensor Replacement: stap 4, afbeelding 2 van 2
    • With your fingers, pull off the (5) standard knobs, (1) stacked knob, and (2) faders.
  5. Akai MPC 4000 Pad Sensor Replacement: stap 5, afbeelding 1 van 2 Akai MPC 4000 Pad Sensor Replacement: stap 5, afbeelding 2 van 2
    • Tilt the LCD display forward to give the panel the clearance it needs to come off, then lift the cover from the device.
    • Remove the pad by lifting it off the sensor plate.
  6. Akai MPC 4000 Pad Sensor Replacement, Sensor Plate: stap 6, afbeelding 1 van 2 Akai MPC 4000 Pad Sensor Replacement, Sensor Plate: stap 6, afbeelding 2 van 2
    • Remove (2) 8mm Phillips screws holding the ribbon cable guard in place.
    • Remove (7) 8mm Phillips screws to free the sensor plate from the board.
  7. Akai MPC 4000 Pad Sensor Replacement: stap 7, afbeelding 1 van 2 Akai MPC 4000 Pad Sensor Replacement: stap 7, afbeelding 2 van 2
    • Slowly lift the back of the plate (from the end closest to the LCD screen), and note where the ribbon cable connects to the board.
    • These cables can become brittle with age; proceed with caution.
    • Carefully pull the ribbon cable and plate from the board.
  8. Akai MPC 4000 Pad Sensor Replacement, Pad Sensor: stap 8, afbeelding 1 van 1
    • Starting from the corner with the ribbon cable, slowly peel the old pad sensor from the sensor plate.
  9. Akai MPC 4000 Pad Sensor Replacement: stap 9, afbeelding 1 van 2 Akai MPC 4000 Pad Sensor Replacement: stap 9, afbeelding 2 van 2
    • Remove the adhesive backing and carefully apply the new pad sensor. Take note of the marks shown in yellow on the plate to aid in the proper alignment and orientation of the new sensor.
    • Smooth out any air bubbles with a plastic card.
    • If the replacement pad sensor you purchased does not include a plastic tab attached to the ribbon cable, remove the tab from the previous sensor's ribbon cable and attach it to the new sensor's. Add additional adhesive if needed.
  10. Akai MPC 4000 Pad Sensor Replacement: stap 10, afbeelding 1 van 1
    • Carefully align the pins of the ribbon cable, and gently guide the cable back into the board applying pressure as needed.
  11. Akai MPC 4000 Pad Sensor Replacement, Troubleshoot: stap 11, afbeelding 1 van 1
    • Before reassembly, orient the sensor plate onto the board, power on the device, and ensure all pad sensors are sending a consistent signal to the device.
Conclusie
Kyle Noonan
193 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 21
Altijd: 133
