Ga door naar hoofdinhoud
Air Jordan 1 Crease and Scuff Removal
Wat je nodig hebt
  1. Air Jordan 1 Crease and Scuff Removal, Air Jordan 1 Crease and Scuff Removal: stap 1, afbeelding 1 van 1
    • Unlace sneakers.
  2. Air Jordan 1 Crease and Scuff Removal: stap 2, afbeelding 1 van 1
    • Stuff toe-box with paper towels until leather is stuffed to capacity.
  3. Air Jordan 1 Crease and Scuff Removal: stap 3, afbeelding 1 van 1
    • Dampen a small towel.
    • Place damp towel across toe-box.
  4. Air Jordan 1 Crease and Scuff Removal: stap 4, afbeelding 1 van 1
    • Using a flat iron, iron over the damp towel to remove toe-box creases.
  5. Air Jordan 1 Crease and Scuff Removal: stap 5, afbeelding 1 van 1
    • Keep the towl on after ironing them to reduce odd cracks.
    • For best results, keep toe-box stuffed with paper towels until you're ready to wear.
  6. Air Jordan 1 Crease and Scuff Removal: stap 6, afbeelding 1 van 1
    • Select Angelus Leather Paint that matches the original color of your shoes.
    • Using a small paint brush, paint over scuffs and scratches with their original color in thin, even coats.
    • Allow 20 minutes in between coats for paint to fully dry.
  7. Air Jordan 1 Crease and Scuff Removal: stap 7, afbeelding 1 van 1
    • Re-lace sneakers.
Conclusie
Once you've completed these steps, your shoes will be ready for wear.
22 andere personen hebben deze handleiding voltooid.
6 opmerkingen
This is the best repair guide in the world.
Mohammad Abdellatif - Antwoord
i love this repair guide.
Best repair guide ever!
Lucas Beauchamp - Antwoord
why and how because i have the all jordan but the only jordan that have a crease is the jordan 12
Azariea Ray - Antwoord
Would this technique work on fearless zoom irridecent ? I know when I have had just a drop of water on then it looks oily almost like there is a fine coat of some sort on them
Brad May - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 66
Afgelopen 30 dagen: 381
Altijd: 91,049
