Inleiding
The plunger is a plastic cylinder covering the main spring which works in the air-releasing system to shoot the darts. You must be careful not to harm other parts of the blaster while taking out the trigger.
Onderdelen
Geen onderdelen nodig.
  1. Using a screwdriver, remove the two 11.6 mm phillips 00 screws holding the grey slider together. Remove grey slider from the main body of the blaster. Remove grey slider from the main body of the blaster.
    • Using a screwdriver, remove the two 11.6 mm phillips 00 screws holding the grey slider together.
    • Remove grey slider from the main body of the blaster.
  2. Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together. Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together. Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together.
    • Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together.
  3. Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed. Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed. Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed.
    • Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed.
  4. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  5. Using a screwdriver, remove the 7.5 mm phillips 00 screw holding the bottom spring to the air system.
    • Using a screwdriver, remove the 7.5 mm phillips 00 screw holding the bottom spring to the air system.
  6. Carefully grab the metal pin keeping the air system and top spring stationary, and slide it outwards. This will release the air system with the plunger completely. Carefully grab the metal pin keeping the air system and top spring stationary, and slide it outwards. This will release the air system with the plunger completely. Carefully grab the metal pin keeping the air system and top spring stationary, and slide it outwards. This will release the air system with the plunger completely.
    • Carefully grab the metal pin keeping the air system and top spring stationary, and slide it outwards. This will release the air system with the plunger completely.
  7. Using a screwdriver, remove the 5.2 mm phillips 00 screw holding the air system to the body of the blaster.
    • Using a screwdriver, remove the 5.2 mm phillips 00 screw holding the air system to the body of the blaster.
  8. Grab the whole air system and carefully take it out of the main body of the blaster. Grab the whole air system and carefully take it out of the main body of the blaster. Grab the whole air system and carefully take it out of the main body of the blaster.
    • Grab the whole air system and carefully take it out of the main body of the blaster.
  9. Now, grab the gray plunger with your hand and slide it outwards to remove it. Now, grab the gray plunger with your hand and slide it outwards to remove it. Now, grab the gray plunger with your hand and slide it outwards to remove it.
    • Now, grab the gray plunger with your hand and slide it outwards to remove it.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alfredo Antolinez
301 Reputatie
3 handleidingen geschreven
USF Tampa, Team 3-1, Brown Fall 2014 Lid van USF Tampa, Team 3-1, Brown Fall 2014
USFT-BROWN-F14S3G1
3 Leden
5 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 1
Afgelopen 7 Dagen: 4
Afgelopen 30 Dagen: 13
Altijd: 313
