Inleiding
The barrel is the orange piece into which you insert the darts.
Onderdelen
Geen onderdelen nodig.
  1. Using a screwdriver, remove the two 11.6 mm phillips 00 screws holding the grey slider together. Remove grey slider from the main body of the blaster. Remove grey slider from the main body of the blaster.
    • Using a screwdriver, remove the two 11.6 mm phillips 00 screws holding the grey slider together.
    • Remove grey slider from the main body of the blaster.
  2. Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together. Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together. Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together.
    • Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together.
  3. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  4. Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed. Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed. Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed.
    • Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed.
  5. Remove the trigger, lifting from the bottom and pulling it out from under the metal pin. Remove the trigger, lifting from the bottom and pulling it out from under the metal pin. Remove the trigger, lifting from the bottom and pulling it out from under the metal pin.
    • Remove the trigger, lifting from the bottom and pulling it out from under the metal pin.
  6. Lift the barrel, pulling it out from under the black trigger catch Lift the barrel, pulling it out from under the black trigger catch Lift the barrel, pulling it out from under the black trigger catch
    • Lift the barrel, pulling it out from under the black trigger catch
Conclusie
Joshua Taylor
101 Reputatie
1 Handleiding geschreven
USF Tampa, Team 3-1, Brown Fall 2014 Lid van USF Tampa, Team 3-1, Brown Fall 2014
USFT-BROWN-F14S3G1
3 Leden
5 handleidingen geschreven
Één commentaar
I don't remember this blaster's shell as being held closed by solvent weld or catches - why is the "iFixit" pry-tool necessary?
Arasin Staubly - Antwoord
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 1
Altijd: 144
