Ga door naar hoofdinhoud
Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement
Wat je nodig hebt
  1. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement, Lens Assembly: stap 1, afbeelding 1 van 3 Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement, Lens Assembly: stap 1, afbeelding 2 van 3 Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement, Lens Assembly: stap 1, afbeelding 3 van 3
    • Remove the battery cover.
    • Remove the batteries.
  2. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: stap 2, afbeelding 1 van 1
    • Unscrew the three 4mm screws from the battery side of the device. Use a Phillips screw driver.
  3. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: stap 3, afbeelding 1 van 1
    • Remove the four screws from the back side.
  4. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: stap 4, afbeelding 1 van 2 Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: stap 4, afbeelding 2 van 2
    • Remove the sticky black dots.
    • Remove the hidden screw.
  5. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: stap 5, afbeelding 1 van 2 Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: stap 5, afbeelding 2 van 2
    • Remove the two screws from the top side of the device.
    • Remove the two screws from the bottom side of the device.
  6. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: stap 6, afbeelding 1 van 1
    • Remove the rear cover.
    • Be careful not to lose the spring inside.
  7. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: stap 7, afbeelding 1 van 1
    • Pull back the front cover so that you can dislodge the side cover.
  8. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: stap 8, afbeelding 1 van 1
    • Unfold the device and be careful not to tear the black and red power supply wires.
  9. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: stap 9, afbeelding 1 van 1
    • Remove the four screws from the motherboard.
  10. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: stap 10, afbeelding 1 van 1
    • Take out the motherboard while disconnecting the flip screen's cable from underneath.
  11. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: stap 11, afbeelding 1 van 1
    • Replace the Lens Assembly board.
    • Be careful not to damage any of the pins. Pull the board linearly.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Gyozo Aba Hivatal
561 Reputatie
5 handleidingen geschreven
USF Tampa, Team 6-4, Brown Winter 2015 Lid van USF Tampa, Team 6-4, Brown Winter 2015
USFT-BROWN-W15S6G4
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 123
