Ga door naar hoofdinhoud
Aiptek Pocket DVII 1.3M LCD Display Screen Replacement
Wat je nodig hebt
  1. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement, Display Screen: stap 1, afbeelding 1 van 3 Aiptek Pocket DVII 1.3M LCD Display Screen Replacement, Display Screen: stap 1, afbeelding 2 van 3 Aiptek Pocket DVII 1.3M LCD Display Screen Replacement, Display Screen: stap 1, afbeelding 3 van 3
    • Remove the battery cover.
    • Remove the batteries.
  2. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: stap 2, afbeelding 1 van 2 Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: stap 2, afbeelding 2 van 2
    • Remove the sticky black dots.
    • Remove the three black 4mm screws from the flip screen. Use a Phillips head screw driver.
  3. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: stap 3, afbeelding 1 van 1
    • Using an opening tool, separate the cover from the screen.
    • The cover won't completely come off. This will happen in the next step.
    • Don't be afraid to use a little more force.
  4. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: stap 4, afbeelding 1 van 1
    • Using an opening tool remove the outside cover of the flip screen.
    • Move the cover towards the lens and then away from the screen.
  5. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: stap 5, afbeelding 1 van 2 Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: stap 5, afbeelding 2 van 2
    • With the cover off, push the brown locking mechanism up, so the picture cable can be remove.
    • You only need to unplug the bottom cable in the picture.
  6. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: stap 6, afbeelding 1 van 1
    • Remove the two black screws from the circuit board.
  7. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: stap 7, afbeelding 1 van 1
    • With the opening tool, pop up the screen assembly.
    • The screen is glued to the black cover. Use more force if needed.
  8. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: stap 8, afbeelding 1 van 1
    • As in step 5, push up the brown locking mechanism of the remaining cable.
    • Unplug the picture cable.
  9. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: stap 9, afbeelding 1 van 1
    • Turn the circuit board over and with a soldering gun remove the two wires on each end.
    • Use a screwdriver to pull the loosened wire away.
  10. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: stap 10, afbeelding 1 van 1
    • With the wires no longer holding the circuit board and screen together, remove and replace the broken screen.
Conclusie
Gyozo Aba Hivatal
561 Reputatie
5 handleidingen geschreven
USF Tampa, Team 6-4, Brown Winter 2015 Lid van USF Tampa, Team 6-4, Brown Winter 2015
USFT-BROWN-W15S6G4
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 352
