Ga door naar hoofdinhoud
Aiptek DZO-V58N Lens Replacement
Wat je nodig hebt
  1. Aiptek DZO-V58N Lens Replacement, Battery: stap 1, afbeelding 1 van 1
    • Locate the battery compartment on the back of the camera. It is the panel with the plastic ridges for simple removal.
    • Slide the battery compartment cover down off of the camera body.
  2. Aiptek DZO-V58N Lens Replacement: stap 2, afbeelding 1 van 1
    • Pry up the battery from the bottom using a finger and remove the batter from the case.
  3. Aiptek DZO-V58N Lens Replacement, Lens Protector: stap 3, afbeelding 1 van 1
    • Remove the lanyard by pulling the grey lace through the black string loop.
    • Pull black string loop through the silver bracket.
  4. Aiptek DZO-V58N Lens Replacement: stap 4, afbeelding 1 van 1
    • Use a plastic opening tool to pry off the black control cover.
    • The face plates are glued, so use force to pry the face plates from the camera body.
  5. Aiptek DZO-V58N Lens Replacement: stap 5, afbeelding 1 van 1
    • Use a plastic opening tool to pry off the ridged back face plate and the black button.
    • The button is loose and should come off with little or no effort.
  6. Aiptek DZO-V58N Lens Replacement: stap 6, afbeelding 1 van 1
    • Use a plastic opening tool to pry off the silver face plate.
  7. Aiptek DZO-V58N Lens Replacement: stap 7, afbeelding 1 van 3 Aiptek DZO-V58N Lens Replacement: stap 7, afbeelding 2 van 3 Aiptek DZO-V58N Lens Replacement: stap 7, afbeelding 3 van 3
    • Open the USB cover to expose the small machine screw.
    • Use the Phillips #00 screwdriver to unscrew the six 0.5cm machine case screws (distributed around the camera body).
    • These small screws are easy to lose. Place the removed screws in an organized container to avoid losing them.
  8. Aiptek DZO-V58N Lens Replacement: stap 8, afbeelding 1 van 1
    • Pull off the side control panel.
  9. Aiptek DZO-V58N Lens Replacement: stap 9, afbeelding 1 van 2 Aiptek DZO-V58N Lens Replacement: stap 9, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Flip open the screen by pulling the loose end of the screen away from the case.
    • Use tweezers to remove the two outside rubber dots to reveal the two 0.5cm machine screws.
    • Use the #00 Phillips Screwdriver to remove both screws.
  10. Aiptek DZO-V58N Lens Replacement: stap 10, afbeelding 1 van 2 Aiptek DZO-V58N Lens Replacement: stap 10, afbeelding 2 van 2
    • Pull the body apart from the bottom of device just enough to make space to remove the silver plastic strap holder.
    • Use tweezers to remove the silver plastic strap holder.
    • Use a plastic opening tool to pry off the lens protector.
  11. Aiptek DZO-V58N Lens Replacement, Lens: stap 11, afbeelding 1 van 3 Aiptek DZO-V58N Lens Replacement, Lens: stap 11, afbeelding 2 van 3 Aiptek DZO-V58N Lens Replacement, Lens: stap 11, afbeelding 3 van 3
    • Unscrew the two silver 0.5cm machine screws with the #00 Phillips screwdriver.
    • Lift off the lens protector housing.
    • Pull apart the two halves of the camera body.
    • Do not pull the two halves apart too far because the wires may detach.
  12. Aiptek DZO-V58N Lens Replacement: stap 12, afbeelding 1 van 1
    • Unscrew both black machine screws holding the lens in place with the #00 Phillips screwdriver.
  13. Aiptek DZO-V58N Lens Replacement: stap 13, afbeelding 1 van 1
    • Carefully remove the compressed springs underneath each of the two screws that were removed in the previous step.
    • Be careful not to lose the springs. The springs are in compression and will launch from the camera if not held onto.
  14. Aiptek DZO-V58N Lens Replacement: stap 14, afbeelding 1 van 1
    • Lift off the lens.
Conclusie
Zachary Yun
7 Reputatie
5 handleidingen geschreven
Cal Poly, Team 5-5, Forte Spring 2012 Lid van Cal Poly, Team 5-5, Forte Spring 2012
CPSU-FORTE-S12S5G5
5 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 12
Altijd: 539
