Ga door naar hoofdinhoud
Afterglow Wireless PS3 Controller Vibration Motor Replacement
Wat je nodig hebt
  1. Afterglow Wireless PS3 Controller Vibration Motor Replacement, Back Cover: stap 1, afbeelding 1 van 2 Afterglow Wireless PS3 Controller Vibration Motor Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
    • Lift up and remove the controller back plate.
    Vraag FixBot
    Voeg opmerking toe
  2. Afterglow Wireless PS3 Controller Vibration Motor Replacement, Vibration Motor: stap 2, afbeelding 1 van 2 Afterglow Wireless PS3 Controller Vibration Motor Replacement, Vibration Motor: stap 2, afbeelding 2 van 2
    • Carefully remove the battery by lifting it straight up from its place.
    • Keep in mind that the red and black battery wires are attached to the motherboard. Handle these with care.
    Vraag FixBot
    Voeg opmerking toe
  3. Afterglow Wireless PS3 Controller Vibration Motor Replacement: stap 3, afbeelding 1 van 1
    • Unscrew the four 9mm Phillips #0 screws that are attached to both joy stick control mini-motherboards. There are two screws for each mini-motherboard.
    Vraag FixBot
    Voeg opmerking toe
  4. Afterglow Wireless PS3 Controller Vibration Motor Replacement: stap 4, afbeelding 1 van 3 Afterglow Wireless PS3 Controller Vibration Motor Replacement: stap 4, afbeelding 2 van 3 Afterglow Wireless PS3 Controller Vibration Motor Replacement: stap 4, afbeelding 3 van 3
    • Jiggle both joy stick control mini-motherboards out of their holding place.
    • Set aside the mini-motherboards so that the vibration motor wire connections are accessible.
    Vraag FixBot
    Voeg opmerking toe
  5. Afterglow Wireless PS3 Controller Vibration Motor Replacement: stap 5, afbeelding 1 van 2 Afterglow Wireless PS3 Controller Vibration Motor Replacement: stap 5, afbeelding 2 van 2
    • Pull both vibration motors straight up from their holding place.
    Vraag FixBot
    Voeg opmerking toe
  6. Afterglow Wireless PS3 Controller Vibration Motor Replacement: stap 6, afbeelding 1 van 1
    • Use the soldering tool to heat the solder connecting the red and black vibration motor wires to the motherboard to detach the vibration motors.
    • Use this guide for further details on how to solder.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Natalie Cox
207 Reputatie
2 handleidingen geschreven
USF Tampa, Team S19-G5, Hoffman Spring 2017 Lid van USF Tampa, Team S19-G5, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G5
4 Leden
20 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 58
Altijd: 1,465
