Ga door naar hoofdinhoud
Afridev Pump Rod Replacement
Wat je nodig hebt
  1. Afridev Pump Rod Replacement, Head: stap 1, afbeelding 1 van 2 Afridev Pump Rod Replacement, Head: stap 1, afbeelding 2 van 2
    • Assemble the required tools, including the Afridev tool and crescent wrenches.
  2. Afridev Pump Rod Replacement: stap 2, afbeelding 1 van 3 Afridev Pump Rod Replacement: stap 2, afbeelding 2 van 3 Afridev Pump Rod Replacement: stap 2, afbeelding 3 van 3
    • Perform a water test on the pump, by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
  3. Afridev Pump Rod Replacement: stap 3, afbeelding 1 van 2 Afridev Pump Rod Replacement: stap 3, afbeelding 2 van 2
    • Loosen the bolt on front of the face plate with the Afridev tool.
    • Remove the plate from the pump by lifting it straight up.
  4. Afridev Pump Rod Replacement, Axle and Handle: stap 4, afbeelding 1 van 3 Afridev Pump Rod Replacement, Axle and Handle: stap 4, afbeelding 2 van 3 Afridev Pump Rod Replacement, Axle and Handle: stap 4, afbeelding 3 van 3
    • Insert the T-handle into the top cylinder of the exposed pump rod.
  5. Afridev Pump Rod Replacement: stap 5, afbeelding 1 van 2 Afridev Pump Rod Replacement: stap 5, afbeelding 2 van 2
    • Loosen the 2 bolts on either side of handle.
    • It is not necessary to remove the bolt at this time; however, take caution to not let the bolt fall out of the handle.
  6. Afridev Pump Rod Replacement: stap 6, afbeelding 1 van 3 Afridev Pump Rod Replacement: stap 6, afbeelding 2 van 3 Afridev Pump Rod Replacement: stap 6, afbeelding 3 van 3
    • Loosen the 2 bolts on either side of the head to remove the handle from the pump rod.
  7. Afridev Pump Rod Replacement: stap 7, afbeelding 1 van 2 Afridev Pump Rod Replacement: stap 7, afbeelding 2 van 2
    • Lift the handle to a horizontal position.
  8. Afridev Pump Rod Replacement: stap 8, afbeelding 1 van 3 Afridev Pump Rod Replacement: stap 8, afbeelding 2 van 3 Afridev Pump Rod Replacement: stap 8, afbeelding 3 van 3
    • While one person lifts up on the T-handle, remove the bolt and connection pieces.
  9. Afridev Pump Rod Replacement: stap 9, afbeelding 1 van 3 Afridev Pump Rod Replacement: stap 9, afbeelding 2 van 3 Afridev Pump Rod Replacement: stap 9, afbeelding 3 van 3
    • Remove the bolt and connection pieces from the handle.
    • Set the bolt pieces in a sanitary place, such as a bucket, to prevent contamination.
  10. Afridev Pump Rod Replacement: stap 10, afbeelding 1 van 2 Afridev Pump Rod Replacement: stap 10, afbeelding 2 van 2
    • Remove the handle from the pump.
    • Be sure to set the handle in a sanitary place to prevent contamination.
  11. Afridev Pump Rod Replacement, Pump Rod: stap 11, afbeelding 1 van 2 Afridev Pump Rod Replacement, Pump Rod: stap 11, afbeelding 2 van 2
    • Grab firmly on the T-handle and lift the pump rod straight up.
    • Expose the first connection of the pump rod, and support the portion below the connection.
  12. Afridev Pump Rod Replacement: stap 12, afbeelding 1 van 2 Afridev Pump Rod Replacement: stap 12, afbeelding 2 van 2
    • While holding the pump rod below the first connection tightly, lower the first portion of the rod to a horizontal position.
  13. Afridev Pump Rod Replacement: stap 13, afbeelding 1 van 3 Afridev Pump Rod Replacement: stap 13, afbeelding 2 van 3 Afridev Pump Rod Replacement: stap 13, afbeelding 3 van 3
    • Unhook the first connection by pushing it out and down, then pulling it away from the rest of the rod.
  14. Afridev Pump Rod Replacement: stap 14, afbeelding 1 van 3 Afridev Pump Rod Replacement: stap 14, afbeelding 2 van 3 Afridev Pump Rod Replacement: stap 14, afbeelding 3 van 3
    • Repeat steps 11-13 for the remaining sections of pump rod.
    • Be sure to set the pump rod segments above the ground to avoid contamination.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jake Devincenzi
117.301 Reputatie
57 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 356
