Ga door naar hoofdinhoud
Advent Modena M201 Hard Drive Replacement
Wat je nodig hebt
  1. Advent Modena M201 Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 1
    • Remove battery, press power button to ensure complete discharge.
    • Remove all screws on the underside, there are no hidden screws
  2. Advent Modena M201 Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Unsnap case , it is best to start at the hinge joints. Work round the case towards the VGA port (RHS). The case needs to pop out over the port so ease the bottom out with your screwdriver. Work round towards the audio jacks (LHS). Lift the RHS of the case up and slide it towards the audio jacks to free them, as the casing cannot be eased over them.
  3. Advent Modena M201 Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • Remove the two screw holding the hard drive caddy in place.
    • Using the plastic tab , lift the caddy up over the screw pillars and pull gentle to the left to unsnap the SATA connector
  4. Advent Modena M201 Hard Drive Replacement: stap 4, afbeelding 1 van 1
    • remove the two screw holding the caddy to the end of the hard drive and attach to the new drive.
    • Reverse the process to reassemble.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Edward
249 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 17
Altijd: 6,602
