Inleiding
The alarm unit is located behind the glove box. Once the glovebox is out of the way, you can remove the black plastic alarm unit, open it and change the dip switch for a less sensitive setting.
Onderdelen
Geen onderdelen nodig.
  1. Once the glove box is out of the way, it's easy to spot the alarm unit. The green connector will be plugged into it. I had already unplugged it when I took this picture.
    • Once the glove box is out of the way, it's easy to spot the alarm unit. The green connector will be plugged into it. I had already unplugged it when I took this picture.
  2. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  3. It may be stubborn to get out because it is stuck down with double stick foam pads.
    • It may be stubborn to get out because it is stuck down with double stick foam pads.
  4. Remove the 4 screws (may be under the foam strips). This is the bottom of the circuit board.
    • Remove the 4 screws (may be under the foam strips). This is the bottom of the circuit board.
  5. Turn the board over and locate the 2 position dip switch.
    • Turn the board over and locate the 2 position dip switch.
    • This dip switch adjusts the glass breakage microphone sensitivity
    • Sensitivity settings:
    • 1 off & 2 off = high
    • 1 on & 2 off = mid (factory setting)
    • 1 off & 2 on = low
    • 1 on & 2 on = super low
Conclusie
3 andere personen hebben deze handleiding voltooid.
mpeeples
184 Reputatie
1 Handleiding geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 6
Altijd: 1,846
