Ga door naar hoofdinhoud
Adjusting Right/Left Speaker Balance
  1. Adjusting Right/Left Speaker Balance, Adjusting Right/Left Speaker Balance: stap 1, afbeelding 1 van 1
    • The balance knob is the rightmost knob on the front panel.
  2. Adjusting Right/Left Speaker Balance: stap 2, afbeelding 1 van 2 Adjusting Right/Left Speaker Balance: stap 2, afbeelding 2 van 2
    • Turning the balance knob to the right increases the sound played by the right speaker.
    • Turning the knob left will increase the sound played by the left speaker.
  3. Adjusting Right/Left Speaker Balance: stap 3, afbeelding 1 van 2 Adjusting Right/Left Speaker Balance: stap 3, afbeelding 2 van 2
    • Turning the knob all the way to the right will make the right speaker play all the sound.
    • Turning the knob all the way to the left will make the left speaker play all the sound.
  4. Adjusting Right/Left Speaker Balance: stap 4, afbeelding 1 van 1
    • The default position is center, which should play the sound equally by both speakers.
    • If this position does not play the sound equally by both speakers, experiment with different knob positions until the speakers play the sound equally.
Eindstreep
Jan Vazquez
239 Reputatie
1 Handleiding geschreven
Cal Poly, Team 27-92, Amido Spring 2010 Lid van Cal Poly, Team 27-92, Amido Spring 2010
CPSU-AMIDO-S10S27G92
4 Leden
7 handleidingen geschreven
Één opmerking
Finally, I can die in peace
john goor - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 5,724
