Ga door naar hoofdinhoud
Adjusting Nishiki Aero II Seat
Wat je nodig hebt
  1. Adjusting Nishiki Aero II Seat, Adjusting Nishiki Aero II Seat: stap 1, afbeelding 1 van 3 Adjusting Nishiki Aero II Seat, Adjusting Nishiki Aero II Seat: stap 1, afbeelding 2 van 3 Adjusting Nishiki Aero II Seat, Adjusting Nishiki Aero II Seat: stap 1, afbeelding 3 van 3
    • Loosen the bolt that secures your seat.
    • To do so, use one wrench to hold the larger nut on the left side of the bike still while you loosen the nut on the right.
  2. Adjusting Nishiki Aero II Seat: stap 2, afbeelding 1 van 2 Adjusting Nishiki Aero II Seat: stap 2, afbeelding 2 van 2
    • Now that it can move, move the seat by wiggling it and pulling it in the direction you want to adjust it.
    • You want to the adjust the seat so that, when a pedal is at the far end of its rotation, your leg is fully extended.
    • Don't worry about getting it perfect on the first try. Instead, guess your adjustment, tighten the bolt a little bit, try it out, and adjust again until you get it right.
  3. Adjusting Nishiki Aero II Seat: stap 3, afbeelding 1 van 1
    • Once your seat is at the desired height, you just tighten the bolt the same way you loosened it.
    • Use two wrenches, one to hold it still and the other to tighten the nut.
    • Make sure it's very tight, or else the seat might twist or lower over time.
Conclusie
Tobias Elder
113 Reputatie
7 handleidingen geschreven
Cal Poly, Team 21-53, Johann Spring 2013 Lid van Cal Poly, Team 21-53, Johann Spring 2013
CPSU-JOHANN-S13S21G53
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 40
Altijd: 2,800
