Ga door naar hoofdinhoud
Adjusting Keurig K75 Platinum Brewing System Reservoir Magnet
  1. Adjusting Keurig K75 Platinum Brewing System Reservoir Magnet, Adjusting Keurig K75 Platinum Brewing System Reservoir Magnet: stap 1, afbeelding 1 van 1
    • Before starting the repair, make sure that the device is unplugged and the water reservoir is empty.
    • Detach the water reservoir from the brewer by lifting the reservoir vertically from the device.
  2. Adjusting Keurig K75 Platinum Brewing System Reservoir Magnet: stap 2, afbeelding 1 van 2 Adjusting Keurig K75 Platinum Brewing System Reservoir Magnet: stap 2, afbeelding 2 van 2
    • The magnet is located in the bottom of the reservoir.
    • Remove the grey lid from the top of the reservoir.
    • Insert your hand and manually realign the magnet to where it slides freely in its enclosed area.
Conclusie
Alexander Vo
94 Reputatie
2 handleidingen geschreven
Cal Poly, Team 20-2, Maness Winter 2013 Lid van Cal Poly, Team 20-2, Maness Winter 2013
CPSU-MANESS-W13S20G2
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 51
Altijd: 19,889
