Ga door naar hoofdinhoud
Adjust the Action (String Height) on Ibanez SR405QM
Wat je nodig hebt
  1. Adjust the Action (String Height) on Ibanez SR405QM, Adjust the Action (String Height) on Ibanez SR405QM: stap 1, afbeelding 1 van 2 Adjust the Action (String Height) on Ibanez SR405QM, Adjust the Action (String Height) on Ibanez SR405QM: stap 1, afbeelding 2 van 2
    • Pay attention to the distance between both the fretboard and pickups.
    • Test the strings by plucking and take note of which ones are difficult to play or are producing an unpleasant metallic sound.
  2. Adjust the Action (String Height) on Ibanez SR405QM: stap 2, afbeelding 1 van 2 Adjust the Action (String Height) on Ibanez SR405QM: stap 2, afbeelding 2 van 2
    • Using a 2 mm Allen Key turn the corresponding string's screw clockwise to raise the string and counterclockwise to lower the string.
    • The screw is located on the bridge of the guitar next to its corresponding string.
    • While modifying a strings height try plucking the string and listening to the sound produced until at desired sound.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Chris Pittner
220 Reputatie
7 handleidingen geschreven
Cal Poly, Team 5-18, Forte Winter 2013 Lid van Cal Poly, Team 5-18, Forte Winter 2013
CPSU-FORTE-W13S5G18
4 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 103
Altijd: 6,125
