Ga door naar hoofdinhoud
Adjust Nintendo DS picture
Wat je nodig hebt
  1. Adjust Nintendo DS picture, Adjust Nintendo DS picture: stap 1, afbeelding 1 van 1
    • First check if the DS has image flickering. It is best to do this with a still image, such as the boot screen.
    • But make sure the backlight is on.
  2. Adjust Nintendo DS picture: stap 2, afbeelding 1 van 2 Adjust Nintendo DS picture: stap 2, afbeelding 2 van 2
    • Loosen the Phillips #00 screw on the battery compartment
    • remove the cover
  3. Adjust Nintendo DS picture: stap 3, afbeelding 1 van 1
    • in these two openings are potentiometers responsible for the image.
    • Above is for the Upper LCD
    • Below for the Lower LCD
    • It's best to check both of them out.
    • Now you can turn on the console and make sure the backlight is on.
  4. Adjust Nintendo DS picture: stap 5, afbeelding 1 van 1
    • Then you can turn left and right with the Phillips #00 screwdriver to adjust the picture.
    • But always take a look at the screens to get a good picture
    • It is also important not to turn too fast and not too far. The trick is to do this slowly and gently.
  5. Adjust Nintendo DS picture: stap 6, afbeelding 1 van 1
    • If everything fits and the LCD screens display the picture well, you can close the battery door.
Conclusie
Close the battery compartment with the battery inside
Met dank aan deze vertalers:
de en
100%
HelloMacOS helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
Patrick Stork
403 Reputatie
1 Handleiding geschreven
2Gids Commentaar
obrigado exelente
Andre Miranda - Antwoord
BOA NOITE
Gostaria de saber se as telas superior e inferior sao iguais??
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 35
Afgelopen 30 dagen: 138
Altijd: 2,989
