Ga door naar hoofdinhoud
Adjust Goose-neck (adjustable quill stem) on Specialized Expedition
Wat je nodig hebt
  1. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition, Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: stap 1, afbeelding 1 van 2 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition, Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: stap 1, afbeelding 2 van 2
    • Remove the bolt cover with a flathead screwdriver.
  2. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: stap 2, afbeelding 1 van 3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: stap 2, afbeelding 2 van 3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: stap 2, afbeelding 3 van 3
    • Loosen the goose-neck (adjustable quill stem) with a 6 mm Allen wrench.
    • After loosening the goose-neck (adjustable quill stem), it still may be stiff. Hold the wheel from turning and twist the handlebars from side to side.
    • If quill stem is still stuck then place 6 mm Allen wrench firmly into bolt and tap with a mallet.
    • Position the handlebars to your preferred height. Make sure not to pull cable and housing to tight. I could adversely effect shifting and braking performance.
    • Make sure you don't raise quill stem above minimum insert line.
  3. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: stap 3, afbeelding 1 van 3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: stap 3, afbeelding 2 van 3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: stap 3, afbeelding 3 van 3
    • Align the direction of the goose-neck (adjustable quill stem) with the front tire.
    • Firmly tighten the goose-neck (adjustable quill stem) bolt using a 6 mm Allen wrench.
    • Pop the bolt cover back on.
    • If calling a bicycle repair shop, refer to it as a adjustable quill stem (technical term) instead of goose-neck as mechanic may not know what you are talking about.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
aaron thielk
1.882 Reputatie
5 handleidingen geschreven
Cal Poly, Team 5-13, Maness Fall 2010 Lid van Cal Poly, Team 5-13, Maness Fall 2010
CPSU-MANESS-F10S5G13
4 Leden
17 handleidingen geschreven
Één opmerking
Anyone know where/how to buy a replacement bolt cover?
Bennett Hart - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 25
Altijd: 9,239
